1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Temperature Sensor
Old 02-24-2011, 09:13 AM
seck's Avatar
seck
seck is offline
Temperature Sensor
Hey everyone, just joined the site. Have a 2000 F350SRW, love the truck, its has the 5.4 V8. Was wondering where the temp. sensor is located. My temp gauge suddenly dopped to the bottom & doesn't work anymore. I don't know if its the gauge or sensor. Any help work be appreciated.
Old 02-25-2011, 12:14 PM
seck's Avatar
seck
seck is offline
Anyone help me out on this????
Old 02-25-2011, 05:24 PM
spinella's Avatar
spinella
spinella is offline
if your talkng about the sensor that gives you the outside temp on your overhead console...its behind the grill on the drivers side. i'll see if i can find a picture of it.
here you go.
https://www.ford-trucks.com/forums/8...re-sensor.html
Old 02-25-2011, 09:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The transmission temp sensor is on the solenoid body, inside the transmission pan.
Old 02-26-2011, 12:04 AM
shorebird's Avatar
shorebird
shorebird is offline
I think that you are asking about the engine temp sensor.
It is located at the upper right rear of the 5.4L engine.
If the sensor itself failed there should be a check engine light and a code set.
P0115 Engine Coolant Temperature Circuit Malfunction
Old 02-26-2011, 12:06 PM
seck's Avatar
seck
seck is offline
Sorry if I didn't clearify, but I meant my engine temperature sensor. My gauge in the dash cluster suddenly dropped to the bottom(blue cold area) & doesn't work anymore. Still have lots of heat. I was trying to figure if its the gauge of possible the sensor that runs the gauge but I can't seem to find the sensor on the engine. Or if anyone has a better way to determine I would certainly appreciate it.
Old 02-28-2011, 06:02 AM
seck's Avatar
seck
seck is offline
-bump bump-
charlie555
03-24-2015 07:36 AM
FionaFarmer
12-01-2011 12:27 PM
ech0sh4y
04-24-2011 09:29 PM
Dragrazor
Electrical Systems/Wiring
28
11-17-2007 10:02 PM
fim
08-24-2000 02:50 PM
Quick Reply: Temperature Sensor
