PATS Ignition Key Programing Question
The Ford dealer here said they would program an after market cut key for $45.
Also asked them how much to get the factory set code for my drivers door exterior keypad entry.They said that would be $45 too.Thats not too bad a quote I guess.
I have a question about programming the third key:
When you say turn it to ON for 1 sec do you mean turn the engine over
or just turn it to auxilary ON where the dash lights up?
Ace Hardware may be the solution
Thank-You!! I just got off the phone and the Ace Hardware here claims they have the programed keys and they cut them too for $59 total.Thats a little more but less hassle going to Ford to program them.Ace guarantees they will turn over the vehicle.Im going there after 1PM when the key guy is there. Gee I may have them today.After I get the 2nd key I can buy them on Ebay and program them myself. BOOYA!!!!!!
I get it at last!
Ahhhh so Ace makes cloned keys that do turn over the engine but they cant be used to make master duplicate keys? If thats the case Ill just pay $21 more and get a master duplicate from Ford Dealer that I can use to make more keys.
Is that correct??
**************OH BROTHER********************
I just talked to a different person at Ford Dealer and they told me that as of 2 wks ago they wont cut aftermarket keys anymore.
So looks like its $80 for a REAL key if I want one to make more keys.It also takes about an hour to do it.
This towns business people drive me nuts.
Is that correct??
Is that correct??
Is that correct??
Call around to the bigger lock shops in your area to see what they can do.
#29
My3rd key is not programming
OK got a 2nd programmed key from ford today($80) and trying to program the 3rd key.Following the directions exactly but no luck.I am turning the keys to on where the dash lights come on and hold it there for 3 seconds each time.The 3rd key fits in the ignition but just runs and runs and it doesnt turn over.I dont know whats wrong.It messes up the computer too and I have to reprogram the 1st and 2nd key after trying to do the 3rd key to get them to work again.I want to make sure I got a bad key for sure before I attack the Ebay guy I bought the 3rd key from.
***I am going to try again and just hold it for 1 second********.
DANG...........it doesnt work!!
#30
I recalled either Walmart or Home Depot or Pep Boys key cutting dept. has an electronic device that can detect if the key has a chip inside. They check that to make sure so they are more careful with the keys so the vibration from the key cutting machine doesn't mess it up. Or they decline to cut them to relieve them from the liability if the machine messes up the chip.
