speed pro forged pistons - Ford Truck Enthusiasts Forums
Old 02-23-2011, 02:38 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
as in the ones that comes in summits fel-pro engine rebuild kits.
anybody use any that can comment on their experience with them? i have a hyper. set for a 351w sitting on a shelf and the look good, but haven't had ran any in an engine.
also does anybody know if they have enough thickness to them for flycutting for valve clearance? I'm not running a "wild" cam, but if i need to do some clearance will i have much to worry about?
edit: also i plan on having the deck milled for zero deck height. what would be the best way to determine how much to have removed?is going off of deck height-piston height-rod length- half of the stroke the only way without having to partially assemble the engine to measure?
Old 02-24-2011, 05:17 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
They are a good piston. There is no way to tell for sure what the deck height is without mocking it up. Get a old rod and have it honed out so the pin will just slide through for checking your deck height.
How to Make Big Power on Low Octane gman97005 Performance & General Engine Building 2 05-06-2013 09:58 PM
Y Block 292 fuel injection conversion AussieDrew Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 17 01-11-2011 07:20 PM
351W stock spec and stroker questions monkei Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 01-20-2009 09:01 PM
351 windsor piston to deck clearance funfor Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-16-2007 02:15 AM
Interesting engine theory read! rusty70f100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 28 11-08-2005 11:25 PM
Tags
1961, 292, 390, 400, clearance, falcon, ford, forged, good, height, piston, pistons, pro, riviews, speed, speedpro, stock, trw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
