IL lift laws?
IL lift laws?
Ok im so confused about this. Im going to install a 4" lift on my 2005 Super Duty and I was looking at the lift laws and it said that a vehicles suspension cannot be modified so that it causes the vehicles bumpers raised or lowered 3"?
Great now what? What kind of law is that?
What do you think? Does anyone have a lifted truck thats over the 3" mark?
Thanks ~Gage~
Thanks ~Gage~
Dont lol I still haven't decided yet, so I have looked at Icon, Pure Performance, BDS, Zone, and Rough Country. I know that I cant go higher than 4.5" because that my bumpers are going to be over 30" in the rear. I still dont know if I should do the install myself or pay someone to do it?
Gage
Gage
625 ILCS 5 sections is Illinois Vehicle Code. 625 ILCS 5/ Illinois Vehicle Code.
(625 ILCS 5/12‑607) (from Ch. 95 1/2, par. 12‑607)
Sec. 12‑607. Suspension System.
(a) It shall be unlawful to operate a motor vehicle on any highway of this State when the suspension system has been modified from the original manufactured design by lifting the body from the chassis in excess of 3 inches or to cause the horizontal line from the front to the rear bumper to vary over 3 inches in height when measured from a level surface of the highway to the lower edge of the bumper, except that it is unlawful to operate a street rod or custom vehicle when the suspension system has been modified from the original manufactured design so that the horizontal line from the front to the rear bumper varies over 7 inches in height when measured from a level surface of the highway to the lower edge of the bumper.
(b) Nothing in this Section shall prevent the installation of manufactured heavy duty equipment to include shock absorbers and overload springs, nor shall anything contained in this Section prevent a person to operate a motor vehicle on any highway of this State with normal wear of the suspension system if normal wear does not affect the control or safe operation of the vehicle. This Section shall not apply to motor vehicles designed or modified primarily for off‑highway racing purposes while such vehicles are in tow or to motorcycles or motor driven cycles.
(Source: P.A. 92‑668, eff. 1‑1‑03.)
(625 ILCS 5/12‑607.1) (from Ch. 95 1/2, par. 12‑607.1)
Sec. 12‑607.1. Frame and floor height. (a) No person shall operate upon a highway a first division vehicle which has a clearance between the frame and ground in excess of 22 inches. The lowest portion of the body floor shall not be more than 4 inches above the top of the frame. No such vehicle shall be modified to cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision or cause the wheels to come in contact with the body under normal operation.
(b) No person shall operate upon a highway a second division vehicle which has a clearance between the frame and ground which is in excess of the limits specified within this subsection for its gross vehicle weight rating (GVWR) category. For the purpose of this section, GVWR means the manufacturer's gross vehicle weight rating whether or not the vehicle is modified by the use of parts not originally installed by the manufacturer. The stacking or attaching of vehicle frames (one frame on top of or beneath another frame) is prohibited. No portion of the body floor shall be raised above the frame.
(1) The frame height of second division vehicles, whose GVWR is under 4,500 pounds, shall be no more than 24 inches.
(2) The frame height of second division vehicles, whose GVWR is more than 4,500 pounds and less than 7,500 pounds, shall be no more than 26 inches.
(3) The frame height of second division vehicles, whose GVWR is more than 7,500 pounds and less than 10,000 pounds, shall be no more than 28 inches.
(c) Under subsections (a) or (b) of this Section, measurements shall be made when a vehicle is unladen on a level surface at the lowest point from the bottom of the original vehicle manufacturer's longitudinal frame rail between the front axle and second axle on the vehicle.
(d) This Section does not apply to specially designed or modified motor vehicles when operated off the highways. Such motor vehicles may be transported upon the highway only by use of a trailer or semitrailer. The specially designed or modified motor vehicle may also be transported upon another vehicle, providing that the entire weight of the specifically designed or modified vehicle is resting upon the transporting vehicle.
(e) Any violation of this Section is a Class C misdemeanor. A second conviction under this Section shall be punished with a fine of not less than $500. An officer making an arrest under this Section shall order the vehicle driver to remove the vehicle from the highway. A person convicted under this Section shall be ordered to bring his vehicle into compliance with this Section.
(Source: P.A. 90‑89, eff. 1‑1‑98.)
(625 ILCS 5/12‑608) (from Ch. 95 1/2, par. 12‑608)
Sec. 12‑608. Bumpers.
(a) It shall be unlawful to operate any motor vehicle with a gross vehicle weight rating of 9,000 pounds or less or any motor vehicle registered as a recreational vehicle under this Code on any highway of this State unless such motor vehicle is equipped with both a front and rear bumper.
Except as indicated below, maximum bumper heights of such motor vehicles shall be determined by weight category of gross vehicle weight rating (GVWR) measured from a level surface to the highest point of the bottom of the bumper when the vehicle is unloaded and the tires are inflated to the manufacturer's recommended pressure.
Maximum bumper heights are as follows:
Maximum Front Maximum Rear
Bumper height Bumper Height
All motor vehicles of the first
division except multipurpose
passenger vehicles: 22 inches 22 inches
Multipurpose passenger vehicles
and all other motor vehicles:
4,500 lbs. and under GVWR 24 inches 26 inches
4,501 lbs. through 7,500
lbs. GVWR 27 inches 29 inches
7,501 lbs. through 9,000
lbs. GVWR 28 inches 30 inches
It is unlawful to operate upon any highway of this State any vehicle with a front bumper height that exceeds 28 inches or a rear bumper height that exceeds 30 inches, regardless of the GVWR of the vehicle, except those vehicles covered by Chapter 18b of this Code.
For any vehicle with bumpers or attaching components which have been modified or altered from the original manufacturer's design in order to conform with the maximum bumper requirements of this section, the bumper height shall be measured from a level surface to the bottom of the vehicle frame rail at the most forward and rearward points of the frame rail. The bumper on any vehicle so modified or altered shall be at least 4.5 inches in vertical height and extend no less than the width of the respective wheel tracks outermost distance.
However, nothing in this Section shall prevent the installation of bumper guards.
(b) This Section shall not apply to street rods, custom vehicles, motor vehicles designed or modified primarily for off‑highway purposes while such vehicles are in tow or to motorcycles or motor driven cycles, nor to motor vehicles registered as antique vehicles when the original design of such antique vehicles did not include bumpers. The provisions of this Section shall not apply to any motor vehicle driven during the first 1000 recorded miles of that vehicle, when such vehicle is owned or operated by a manufacturer, dealer or transporter displaying a special plate or plates as described in Chapter 3 of this Code while such vehicle is (1) being delivered from the manufacturing or assembly plant directly to the purchasing dealer or distributor, or from one dealership or distributor to another; (2) being moved by the most direct route from one location to another for the purpose of installing special bodies or equipment; or (3) being driven for purposes of demonstration by a prospective buyer with the dealer or his agent present in the cab of the vehicle during the demonstration.
The dealer shall, prior to the receipt of any deposit made or any contract signed by the buyer to secure the purchase of a vehicle, inform such buyer, by written statement signed by the purchaser to indicate acknowledgement of the contents thereof, of the legal requirements of this Section regarding front and rear bumpers if such vehicle is not to be equipped with bumpers at the time of delivery.
(c) Any violation of this Section is a Class C misdemeanor. A second conviction under this Section shall be punishable with a fine of not less than $500. An officer making an arrest under this Section shall order the vehicle driver to remove the vehicle from the highway. A person convicted under this Section shall be ordered to bring his vehicle into compliance with this Section.
(Source: P.A. 92‑668, eff. 1‑1‑03; 93‑702, eff. 7‑9‑04.)
