Short bed dually years? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-23-2011, 07:40 AM
Castertroy's Avatar
Castertroy Castertroy is offline
Castertroy is starting off with a positive reputation.
I'm having a hellova time putting the right words together in "SEARCH" mode to find what years ford produced the dually in short bed form.
I'd really like to look for a 4x4 crew cab dually SHORT BED....but I need to know what years for produced them.
I think it was limited....like 2002-2004. Can anyone verify that?
Did ford produce shortbed dually's AFTER 2005?
Thanks soo much in advance!
Old 02-23-2011, 08:31 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
The only year I know of is in '01.
Old 02-23-2011, 08:34 AM
Anomic Anomic is online now
Anomic is starting off with a positive reputation.
Just curious what are your plans for one? Unless you are carrying led bricks bed is to small to use extra capacity and sb can be an issue with some 5th wheel applications
Old 02-23-2011, 08:46 AM
Castertroy's Avatar
Quote:
Won't be using a gooseneck or 5th wheel application. "bumper" tow trailers are all I have. I simply prefer a shorter overall truck, but I DO want 4 full doors.
I've seen several of them around for sale...but now that I'm in the position to BUY one....can't seem to find one Just wondered what years I needed to plug into autotrader/craigs to see
Old 02-23-2011, 08:52 AM
jim48's Avatar
jim48 jim48 is offline
jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.
I know what you mean. I was dissappointed Ford's lack of shortbed dually. We went to a Dodge dealer and looked at their shortbed dually. However, Dodge does not make that truck in a supercab. My reasons for wanting shortbed dually was simply to lessen overall length. I only wanted weight carrying capacity for 5th wheel pin weight. I had a Pullrite SuperGlide. So, didn't have to worry about hitting cab. Anyhow, with all that said after 7 happy years with last truck (04 F250 SB,SRW,4x4). I ordered F350 Lariat Chassis cab 2WD and gave up wishing for Ford SB. You could always go shortbed F350 SRW, sell bed and do flatbed. But if you do F350 dually and sell bed it will still be longbed frame. I wrestled with all that for over two years. I have 275 miles on new truck, just getting some breakin miles on engine while waiting for aluminum bed to be made. Hope you find a solution to your needs.
Old 02-23-2011, 08:57 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Ford did produce short bed duallys after 2005, here is some proof...
Old 02-23-2011, 09:10 AM
Gofigurethis_01's Avatar
Gofigurethis_01 Gofigurethis_01 is offline
Gofigurethis_01 is gaining momentum as a positive member of FTE.
Quote:
Most definitely, I have seen them on the web and one in person on a dealer lot.
Try searching with f350 156 drw, where 156 is the wheelbase of a crew cab short box.
Seems to me there was alot of '99-'04, only seen a couple '05-'07. I'm sure the truck you want exists, you just have to find it.
Old 02-23-2011, 09:38 AM
Franko72's Avatar
Molon Labe
I see quite a few here in FL. Not too many new ones, but they are out there.
Old 02-23-2011, 11:11 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
They produced them through the 2008 model year. They were discontinued sometime in late '08 - early '09. I know there were 2008 models but I think that was the last year......no 2009s.
Old 02-23-2011, 12:01 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I know they made them as early as 2000 because there is a guy selling the bed off one locally.
Old 02-23-2011, 01:34 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
Old 02-23-2011, 02:34 PM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
If the second one had a stick in it --- I'd go buy it for a ranch /haul truck - although lifted a little too high for me..
Old 02-23-2011, 02:46 PM
rollerstud98's Avatar
rollerstud98 rollerstud98 is online now
rollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud of
Quote:
I thought they made them right up until 2010?
Old 02-23-2011, 03:41 PM
They got discontinued either at the end of the '08 model year or early in the '09 model year. The 2010 order guide doesn't show them as available.
Old 06-03-2011, 09:19 AM
Castertroy's Avatar
FOUND ONE!
The perfect one!
Bed Supports 06Dually 1999 to 2016 Super Duty 1 11-02-2014 06:34 PM
Short bed dually? RUN52 1999 to 2016 Super Duty 7 01-19-2013 02:31 AM
1949 F-3 dually box questions vwjunkie53 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 09-28-2010 05:34 AM
First ford dually oldjag 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-31-2007 02:25 PM
76-79 Ext Cab S/B Dually? Chuky66 Car/truck Buying Advice 3 07-21-2002 03:54 AM
Tags
2010, 450, bed, change, dualley, dually, dullay, dully, f350, ford, sale, short, small, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
