AutoEnginuity cylinder contribution test
Old 02-22-2011, 10:16 PM
desertt5's Avatar
desertt5
desertt5 is offline
Has anyone used AE and upgraded connector to check which injector is bad/weak? Trying to see how well it works and if its worth it.
Old 02-23-2011, 05:05 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
I'll bump this back to the top, someone with AE will chime in.
Old 02-23-2011, 05:07 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I knew they were working on it but didn't know it had been released yet??? I'd like some information on this too.
Old 02-23-2011, 08:35 AM
Bill168's Avatar
Bill168
Bill168 is offline
I recently purchased AE, so I'm not sure about the "upgraded connector". I can tell you it worked very well for finding bad injectors. Mine will do the power balance test, but I found that being able to turn off injector one at a time while it's running to be the most useful. Started out with a code for the #2 cylinder, turning of #2 while running made no difference. Turning off #1 didn't either. Changed #2 and tested again and #1 had a power balance code. Changed #1 injector, problem solved. The power balance test showed an RPM increase on the #1 cylinder. I suspect it was dripping excess fuel into the cylinder, and I did have a lot of white smoke until that injector was changed.
I'm not sure if I have answered your question or not, as I'm not sure if I have the old or new connector (I purchased it in Jan of this year), but either way, it allowed me to diagnose 2 injector problems and pin point which injectors were bad. So in my opinion, it works very well, and it was worth every penny I paid for it.
Old 02-23-2011, 08:57 AM
Bill168's Avatar
Bill168
Bill168 is offline
I have also read that when one injector fails, the rest wont be to far behind it. The power balance test also showed a slight RPM increase in the #8 cylinder. But turning that injector off with the engine running made a big difference in the way it ran. It will be interesting to see if #8 is the next injector to fail. The truck is an 04 with a 6.0 in it. I did this test on a friends 06 and the line was flat. If #8 is the next one to fail, that would tell me the power balance test is a good indication of which injectors are on their way out. Only time will tell.
Old 02-23-2011, 11:17 AM
desertt5's Avatar
desertt5
desertt5 is offline
Bill, you should have a new connector. I think it is labeled with Proline. Mine has AutoEnginuity only. I called them and was told I would need a newer conector.
Sounds like it will be worth the money. It is around $100 for me to upgrade. Had mine for over a year now. Helps that 3 of us may be splitting th cost.
I have at least one injector suffering from stiction, maybe more, and an intermittent miss when warmed up. I was planning/ hoping to just replacethem all, but after a rebuilt trans and fuel pump and blue spring and.........
Old 02-23-2011, 11:27 AM
Zmann's Avatar
Zmann
Zmann is offline
Old 02-23-2011, 11:29 AM
Zmann's Avatar
Zmann
Zmann is offline
you need to download the update and contact A/E for a new code
if it's too old you may need to pay for the update
Old 02-23-2011, 11:31 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Scott -
Other than selecting "power balance" on the drop down menu and clicking on "initiate" do you have to do anything else to get the info to display in graph form? I've got the proline connector but I haven't been able to get the data to display in a graph.
Old 02-23-2011, 12:36 PM
Zmann's Avatar
Zmann
Zmann is offline
Steve what do you see??
Old 02-23-2011, 12:38 PM
SteveBricks
Number data
Old 02-23-2011, 12:39 PM
Zmann's Avatar
Zmann
Zmann is offline
Steve you need the update
Downloads
Old 02-23-2011, 12:43 PM
texans's Avatar
texans
texans is offline
Just used mine for the first time the other day. It worked great. Steve mine came up in graph form.
Old 02-23-2011, 12:48 PM
SteveBricks
Thanks a bunch, Scott That update looks like it came out right around the time my unit shipped
Old 02-23-2011, 12:51 PM
Zmann's Avatar
Zmann
Zmann is offline
lol!
they are usually fast at getting you the activation code
the old mumeric contribution test was almost usless IMHO but it beat the previous no contribution test
Quick Reply: AutoEnginuity cylinder contribution test
