Squeaks and rattles HELP! - Ford Truck Enthusiasts Forums
Old 02-22-2011, 09:32 PM
TurboDiesel5 TurboDiesel5 is offline
TurboDiesel5 is starting off with a positive reputation.
I am having some trouble with the old F-250... I am having some issues with a terrible squeak in the dash when I go over a bump and there are rattles that are driving me crazy! I took it to the dealer and got the "I don't hear it" excuse... I demonstrated it to him even and then I got the ol' "Thats normal" excuse. It didn't do it when it was brand new and now that it has 8,000 miles on it, they are getting worse. I just want them to stop, I have been complaining about them since it had 3k on the odometer, and they won't fix them. Anyone else having these troubles? If there is a Ford engineer running around please please help me. This is a nearly $60k truck I don't use it off road, shouldn't it wait a little longer to start making all these noises at me? Any ideas?
Old 02-22-2011, 09:36 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Take a video of it, post it on here...
Old 02-22-2011, 09:38 PM
I will when I return home... All I have is my Droid, I don't know how sensitive the mic is, but I will try it for sure!!
Old 02-23-2011, 09:41 AM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
Yea, Mines got a rattle on the passenger side when hitting small bumps like on a gravel road.. I have cleared all the "junk" out of the door pockets as well as the glovebox to see if is that making the noise & it's still there..
Next I am gonna take off the door panel & make sure all is tight.. but it actually seems a little further forward like under the dash.. or maybe up under the floorpan near the firewall..
Yea - it real aggravating - with only 15K, but I cannot blame Ford totally because the roads I drive tend to loosen things up ...
Old 02-23-2011, 09:48 AM
I have that one, plus the squeak in the dash... I don't drive any terrible roads, it has mostly seen I-20 and other well paved roads. I don't know why it is doing it or how to get it solved. I've called Ford for problems, and I always get the same answer, take it to another dealer.... I don't have any other dealers to go to. I just want it to be fixed.
Old 02-23-2011, 10:22 AM
11350KINGRANCH's Avatar
11350KINGRANCH 11350KINGRANCH is offline
11350KINGRANCH is starting off with a positive reputation.
This is my one major complaint about the truck. I love everything else. My thinking is that a $65,000 truck shouldn't be making these noises when it is new.
Old 02-23-2011, 10:33 AM
chris8084's Avatar
chris8084 chris8084 is offline
chris8084 is starting off with a positive reputation.
I have some sort of rattle in mine as well. I only have 900 miles on the truck and it driving me crazy. I am still trying to find the source before I take it to the dealership. Seems to be coming from the middle part of the dash.
Old 02-23-2011, 10:42 AM
Quote:
That is where mine is. I'm about ready to start taking the dash apart to find it.
Old 02-23-2011, 11:20 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I have a rattle in the middle of my dash, sounds as if behind the radio.
It shows up around 1,100 RPM so mostly when I'm driving in/out of my subdivision.
Old 02-23-2011, 04:35 PM
Med Sun Med Sun is offline
Med Sun is starting off with a positive reputation.
I got one too, mine sounds like its the mirror on the drivers side but I am not definite. I have 800 miles on the truck.
Old 02-23-2011, 05:41 PM
Tacswa3 Tacswa3 is offline
Tacswa3 is starting off with a positive reputation.
Same here, behind the radio. Sounds like a small marble rolling around to me. My driver's door squeaks and tweaks to as the truck flexes over bumps and such. Annoying as hell.
Old 02-23-2011, 09:06 PM
Biggziff's Avatar
Biggziff Biggziff is offline
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
Sheesh...my 05 with 130K on it had ZERO rattles/noises in it... Maybe I should have kept it?
Old 02-23-2011, 09:55 PM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
Quote:
Yup, when my truck gets in the twisties it sounds like the truck is going to break apart.
Old 02-23-2011, 10:15 PM
chris8084's Avatar
I think it's coming from the top of dash storage bin. If I apply downward pressure to the bin Thingy it goes away! These trucks should NOT rattling or squeaking! It's really annoying.
Suspension Squeak at 20k 93-331-29PSI 6.7L Power Stroke Diesel 6 09-28-2015 04:32 PM
Squeak/rattle behind the dash - help requested. NMSU_RRAggie Excursion - King of SUVs 4 06-27-2015 12:34 PM
2000 F250 Triton V10 New to me Brakes won't stop squeeking. Merlin Miller 1999 to 2016 Super Duty 1 07-18-2014 08:46 AM
Squeaky Brakes Strokt350d 6.2L V8 6 07-02-2014 07:53 AM
"Squeaks, rattles and pops" - how do these/your truck rate? Tennesseestorm 2009 - 2014 F150 21 08-10-2011 04:33 PM
Tags
2001, 2009, 2011, bin, bumps, dash, doors, escape, expedition, f250, fix, ford, lariat, rattles, rubber, squeak, squeaking, storage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
