You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 1989 Make: Ford Model: F-150 Price: $2500 Mileage: 186000 Color: RED Private or Dealer Listing: Private Listing Location (State): KY Transmission: Manual Drivetrain: 4WD & AWD Color: Red Engine: 4.9L
1989 Ford F-150 XLT Lariat 4X4 Long Wheel Base
4.6L (Inline 6 cyl) Engine, Mazda 5 speed OD Transmission, with Borg Warner Transfer Case
Showing 80,000+ miles. (Im sure this is probably 180,000)
Would make an excellent Hunting, Fishing, Work, or Farm Trk.
Engine holds great oil pressure, new clutch & transmission is ok also.
I have had the trk for 2 years & use it for hunting, fishing, & driving to work in the snow.
Drove it to Ballard County & Henderson County throughout the past 2 hunting seasons with no mechanical problems.
Body is sound but used. I have replaced the bed because the other one was rusted over the fender wells.
I have replaced the following with all new parts:
New Moog front bearings, inner & outer, spindle bearings, & all seals, brake hubs, front & rear brake pads, calipers, brake lines, New Warn Lockable Hubs. New Moog axle u-joints in the front end, new Red Head steering gear, new upper & lower Moog greaseable ball joints, Moog greaseable tie rod ends, all new Moog u-joints in the front & rear driveshafts. Moog camber bushings. New speedo cable, all new radius arm bushings, New metal brake lines from the cab back. New Moog front coil springs. New 19 gal. fuel tank & fuel pump inside the tank. New front (takes 4) Monroe shocks. New shocks on rear also.
All new radiator hoses, serptine belt, new Ford Motorcraft Plugs, Wires, & Distributor Cap. New EGR valve. New Water Pump, New Oil Pump, All new Fel-Pro rubber valve cover & oil pan gaskets. New exhaust from catalytic converter back.
ALL NEW PARTS, NO JUNK YARD PARTS.
Pulled out rotten carpet & replaced with new vinyl mat.
I also have an extra Warner T-18 4 speed Transmission (1st gear is bulldog) & Transfer Case with bellhousing from an 1987 that was totaled in the tornado in 2008 that goes with this truck also. Everything is inner changeable.
Everything on the trk works except the air conditioner. I have another compressor but never put it on. Has tilt wheel & cruise control.
I took out the rear gas tank.
If interested please reply by e-mail. Located in Western KY.
How did you remove the rear tank. I have an 87 that needs this done to it. If you could tell me I'd sure appreciate it. You can pm me if you want. Thanks and good luck selling.
__________________
87 f150 4x4 302 4spd no od. 3.55 gears. 33 12.50/15's on rock crusher's. Sold to me brother in law.
