Bed Bolts
I'd read all the threads and posts about how hard it is to get the bed bolts out. When I had to take my bed off, I took about 40 minutes to prepare; got out the torch, impact wrench, quality sockets, two foot breaker bar, 5 pound hammer, die grinder with cut off wheel... I was loaded for bear!
Did I feel "stupid" when a good hard tug on the 3/4 inch ratchet broke every one of them free.
Gives new meaning to the old saying, "I'd rather be lucky than good anyday."
Thanks guys. I'm going to get a couple of impact rated bits and hopefully I'll be able to take my 11 year old bolts out!! The guy I bought the new bed off of gave me brand new bolts to go with it which is good, cause I'm sure I'll break at least one or two of the original rusty ones.
If you've been dealing with the sand and salt on the roads here in MA for the last 11 years I'd go buy some fresh cutting wheels before you start and be ready to grind the heads off the bolts
I just had to google it... interesting
A Torx variant, Torx Plus, introduced about 1990 when the original Torx patent was expiring, is designed to allow greater torque, and to minimize wear. The specifications for these licenses are held by Textron. Standard Torx drivers can be used to drive Torx Plus screws, but not to full torque because of the loose fit. Torx Plus drivers will not fit standard Torx screws. They are shortened to "Torx TX".
