Hey guys my speedometer quick working and I checked the owners manuel and searched online but cant find what fuse feeds the speedometer.is it the same one that feeds the cruise control?
Mine quit a couple of years ago and like Andy says it was the VSS sensor on the top of the rearend.. Napa has the sensor..(they call it a ABS sensor) P/N 530780 for around $12.. easy to replace..
I agree Robin.. if there is alot of miles and no fluid chg on the rearend.. this would be a good time to change it out.. (eliminate those metal pieces)
Thanks for the responces it was the speed sensor I guess I blew it loose with the pressure washer the other day. I pushed the connector back on tight and its working.
thanks again guys this really is a great site with all its helpful people.
Thanks for the follow up. My 2000 did the same thing. I wiggled the wires and problem fixed. My favorite 0$
