Fuel Pump Help - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Fuel Pump Help
  #31
Old 02-24-2011, 12:26 AM
Cowboydandy Cowboydandy is offline
Cowboydandy is starting off with a positive reputation.
I did the pump on my 1997 F-250 HD 7.3 PSD , its the the same set-up as yours . It took about an hour to do, but I'm real Good . Find another auto repair shop to go the work. Alldata shows 6.3 Hours to R&R the Pump. O'Reilly's has the pump - Airtex 61067 , for $99.99 . Airtex is the OEM. For the 7.3 PSD. Good Luck
  #32
Old 02-24-2011, 06:00 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
Quote:
Originally Posted by RÖENTGEEP View Post
Or you can fab a table like mine with a fraction of that price and works awesome and you have place for tools, rags, etc.
look here:
Mobile Photobucket?
That is a good idea!
Do you think maybe next time you are playing the camera you can take some more pictures of? I can't see it to well.
  #33
Old 02-24-2011, 07:17 AM
Robbgt's Avatar
Robbgt Robbgt is offline
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
Ian, If you click "next" on the photobucked page he posted up, you can see alot more pictures of the bench and where the supports sit in the engine bay. Pretty cool, may have to make myself one
ALSO Tried to rep you RÖENTGEEP for helping with the camshaft idea to keep the pump tappet from dropping... but still in rep jail. I think we need a re-working of this rep system... what happens if the same people are the ones always helping out?
  #34
Old 02-24-2011, 07:39 AM
Copedawg's Avatar
Quote:
Thanks Robb! I see now. This will be a summer project....I just need to add a beverage holder and I will be like "downtown"!
  #35
Old 06-25-2013, 01:09 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question
Quote:
Ian I havent see you here often. What happened, did you make the "table" with the holder?
  #36
Old 06-25-2013, 03:56 PM
sowaxeman sowaxeman is offline
sowaxeman is starting off with a positive reputation.
So I see you dug up this thread from the dead ;-) Figured I'd provide an update on my Fuel Pump experience. In March of 2011 (one month after this thread died) I blew out my knee. I've since had three surgeries on it, so obviously climbing on top of this truck was not in the cards. I found another local diesel mechanic that was about 45 minutes from home...he quoted me $250 to install my pump and o-ring kit that I had purchased. Naturally I asked him when I should drop it off! He got the pump installed in less time than he estimated and tried to charge me only $225. I gave him the $250 and told him go buy a bottle of his favorite liquid encouragement...and THANKS!
To date I have been leak free (and diesel fume free), and all calculations indicated I was losing 5mpg to the leak!!!
FAST EFI FUEL PUMP WITH 2 TANKS---HELP!!! 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-25-2012 12:31 AM
2001 F150 5.4 fuel tank and pump removal G5.4 1997 - 2003 F150 1 03-20-2011 06:33 PM
2002 Excursion fuel pump montgomery7 Excursion - King of SUVs 3 02-18-2010 10:16 AM
fuel pump relay location csuteau 1999 - 2003 7.3L Power Stroke Diesel 3 08-19-2008 05:24 PM
1987 F150 6 300 CI, fuel pump & relay locations??????? sagesprings 1987 - 1996 F150 & Larger F-Series Trucks 1 10-17-2003 09:06 AM
Tags
107, 2164, 61067, 97, airtex, f350, failure, ford, forum, fuel, hard, m61067, network, pump, sova, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
