Fuel Pump Help - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Fuel Pump Help
Old 02-22-2011, 01:20 PM
sowaxeman sowaxeman is offline
sowaxeman is starting off with a positive reputation.
So how do I determine if my truck is Cali or 49 state?
Old 02-22-2011, 01:23 PM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
If the fuel pump has a large round disk on it. Looks like the starship Enterprise.
Old 02-22-2011, 02:41 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Quote:
Here are some pics of the cali fuel pump and the sticker.
Old 02-22-2011, 05:51 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Quote:
Originally Posted by DIYMechanic View Post
The way I understand it these pumps are all made by the same manufacturer regardless of whose name is on it. They are made by Carter and therefore, the best price wins as far as I am concerned. Can someone who knows more about these correct me if I am mistaken?
That's how I understand it as well. I chose the Bosch one at AAP because it had a lifetime warranty and was the same price(after the coupon) as the O'Reilly one with a 90 day warranty.
Old 02-22-2011, 10:11 PM
1973dieselhighboy's Avatar
1973dieselhighboy 1973dieselhighboy is offline
1973dieselhighboy is starting off with a positive reputation.
do it your self it is really easy all you need is a knife 1/4 drive socket al 6 inch extention, 10mm socket, 13mm socket, 15mm wrench, 1 1/4inch wrench and about 2 hours to do it, just drain the fuel bowl using the water drain, remove the t intake from the turbo to heads, then disconnect the electrical connector on the left side of the fuel bowl looking at the engine, then cut the upper line that runs between the bowl and pump, undo the clamp on the lower single hose in the valley between pump and bowl, remove the 2 return lines to the bowl from the heads using the 15mm wrench and cut or slide the return line from the bowl to the hard line, its the short 2 inch hose that is vertical, remove the water drain vavle hose, remove the 2 13mm bolts on the back side of the bowl, pull the bowl out but dont lift it out all the way make shure you disconnect the ipr connector then the bowl will come all the way out, removed the 1 1/4 inch banjo bolt on the back of the pump, cut or remove supply line to pump and then unbolt pump and use a ladies foot pry bar or a 90 degee pry bar and wiggle the pump as it comes out, just put the new pump in and assemble it i do them in about and hour to a hour and a half but i have done probably 10-20 of them really easy not worth the even 400 bucks the other shop quoted you.
Old 02-23-2011, 09:09 AM
This is why I love internet forums when it comes to my cars (and now my truck). Thanks for all the help guys!
I bought that fuel pump/hose/o-ring kit for $140 with free shipping. Now I will just pick a nice weekend when I am bored and have at it.
Anyone ever take their hood off for this job? I was thinking of doing that and working from a short step stool from the sides (I'm 6'1") rather than crawling on the engine.
Old 02-23-2011, 09:15 AM
Robbgt's Avatar
Robbgt Robbgt is offline
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
I don't really think you would need to take the hood off... you should have plenty of room with a tall step stool. or just use some house scaffolding.. that's what i do for lengthy projects
Old 02-23-2011, 11:19 AM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Old 02-23-2011, 11:38 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
Quote:
Originally Posted by Action4478 View Post
SWEEEEEEEEET!
Old 02-23-2011, 05:56 PM
J'S97F-350's Avatar
J'S97F-350 J'S97F-350 is offline
J'S97F-350 is starting off with a positive reputation.
SOWAXEMAN, glad to see you are goin to do it youreself!! When you go to remove the pump only loosen the 2 pump retaining bolts 1/8 to 1/4 inch, then rotate the crank shaft by hand until you see the pump begin to rise up. at that point you can proceed with remove ing the bolts and the pump. This will prevent the pump tappet from falling into the engine...normally the tappet stays in the pump but this is good insurance.
Good luck
Jason
Old 02-23-2011, 07:57 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Talking
Quote:
Originally Posted by Copedawg View Post
SWEEEEEEEEET!
Or you can fab a table like mine with a fraction of that price and works awesome and you have place for tools, rags, etc.
look here:
Mobile Photobucket?
Old 02-23-2011, 08:08 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Exclamation
Quote:
Good luck
Jason
Some times you dont see when the pump begin to rise up, if so, you have this other tip (IIRC its from Redman):
Look at the pulley for the camshaft. There is a mark to indicate the position of the counterweight. Use a 1/2" dr ratchet w a 13/16" socket and turn the engine by hand until that mark is at the 11 o’clock position. Then it is safe to pull the pump out. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
  #28
Old 02-23-2011, 08:13 PM
Yep , line the dampener mark with the indicator on the CPS ...
  #29
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Excellent tip. Tried to rep you but I'm in jail.
  #30
Old 02-24-2011, 12:15 AM
Cowboydandy Cowboydandy is offline
Cowboydandy is starting off with a positive reputation.
I did the pump on my 1997 F-250 HD 7.3 PSD , its the the same set-up as yours . It took about an hour to do, but I'm real Good . Find another auto repair shop to go the work. Alldata shows 6.3 Hours to R&R the Pump. O'Reilly's has the pump - Airtex 61067 , for $99.99 . Airtex is the OEM. For the 7.3 PSD. Good Luck
88 ford truck Monsterford22 1987 - 1996 F150 & Larger F-Series Trucks 14 09-14-2016 08:47 PM
1986 ford econoline fuel pump wiring help dennison.7 1968-2013 Full Size Vans 3 05-03-2015 10:09 PM
fuel pump acfd813 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-09-2013 10:01 AM
FAST EFI FUEL PUMP WITH 2 TANKS---HELP!!! 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-25-2012 12:31 AM
fuel pump ? Bronco86 1978 - 1996 Big Bronco 9 12-26-2003 08:07 PM
Tags
107, 2164, 61067, 97, airtex, f350, failure, ford, forum, fuel, hard, m61067, network, pump, sova, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
