Belt tension pully is bouncing
I have a 2000 Explorer that I did the front jack chain tensionors on last summer. I was hearing a similar noise so I was looking under the hood and noticed the serpentine belt tension pulley was bouncing quite a bit and that was where the noise is coming from. When I stood and watched the belt for a while it looked like the main crank pulley was out of round and that is what was causing the belt tensionor to bounce. How could that pulley be out of round?
Chances are better than one of the bearings is bad either in the tensioner, an idler pulley, or the alternator. A rough spot in a bearing could cause the belt to bounce and would be much more likely than an out of round crankshaft pulley.
If it were my truck, I'd remove the belt and spin the mentioned pulleys by hand to see if one or more have a rough feel and sound when spinning.
-Rod
-Rod
Fordication
11-17-2016 12:13 PM
Rusty_S
04-05-2015 01:43 PM
3speed
04-01-2011 11:44 AM
93RangerXL4x2
03-06-2011 07:26 PM
for4feet
20
01-09-2011 09:52 AM
