FAQ - Diesel - 6.9 Block Casting (is your 6.9 prone to cracks near the block heater?) - Ford Truck Enthusiasts Forums
'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
Closed Thread
Old 02-21-2011, 12:25 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
<table style="background-color: rgb(218, 222, 235); text-align: left; width: 810px;" border="1" cellpadding="5" cellspacing="0"><tbody><tr><td style="vertical-align: top;">
Provided by Dave Sponaugle
<table style="background-color: rgb(244, 244, 254); text-align: left; width: 800px;" border="1" cellpadding="5" cellspacing="0"><tbody><tr><td style="vertical-align: top;">
Do I have a Good Block?
Quote:
Originally Posted by Dave Sponaugle View Post
Here is a list originally posted by Pete, PLC7.3 that gives the best run down I ever saw.
And looking at the list, you block is fine.
6.9 blocks up to serial #u2u17900 had a thinner casting around the block heater. It is very common for these blocks to crack.
6.9L Old Style Block
Block Casting Number:
On left side of block (beneath oil cooler) 1805440C1
Note: Some 440 blocks are truly new style and must be visually inspected by raised donut around the block heater, frost plug (right rear). Old style below serial number 173828.
Visual Identification: *No counter bored area for block heater
*No defined area on side of block for dip stick
*Thickness of cast iron around block heater 3/8" (.375")
Head Bolts: *7/16, 12 point socket is used to torque head bolts
*Block tapped with 7/16-14 for head bolts
6.9L New Style Block
Block Casting Number: 1807996C1 Note: Some new style blocks have casting
number 440. Above serial number 173828.
Visual Identification: *Has counterbored area for block heater
*Very defined relief area cast in side of block for dip stick tube.
*Thickness of cast iron around block heater 15/32" (.470")
*Latest style (not all new style 6.9) has ribs around head bolts, rear two on left side go from head gasket surface to pan rail - same as 7.3
Head Bolts: *Same as old style 6.9
</td></tr></tbody></table>
End close of outermost table
Closed Thread
FAQ - Exploded View Diagrams (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 08:00 PM
FAQ - How to identify your automatic transmission ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 07:46 PM
FAQ - How to determine if engine is a 302 or 351W ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 01:20 PM
FAQ - Wheel Technical Information (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-08-2011 09:18 PM
FAQ - Kelly hotrod - Ford Engines (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 01-15-2011 09:10 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
6.9 block cracks, 6.9l block cracks, diesel block cracks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
