SCT Custom Tunes
SCT Custom Tunes
I'm in the market for an SCT Programmer. There's a lot of different options out there from what I can see. I've heard all sorts of advocacy for Innovative and DP Tuner. I've heard Jodi's name mentioned. Has anyone used any of the tunes from MKM Customs? They claim to have a guy Mike that has been doing their in-house tuning for quite some time. Just trying to weigh all the options.
Thanks,
Thanks,
I want blame it all on mkm but I will blame some...... They fried my turbo!!!!! The tune I got wasn't creating enough boost at idle to cool the turbo and it burned the seal then causing my center housing to wear in turn costing me for a new turbo.... THANKS. But with all tunes it's at your own risk.
Josh
In all seriousness, boost don't cool down a turbo. Oil cools and lubes the shaft/bearings. Allowing the turbo to cool down after a hard run/drive and before shutting down will allow the oil to cool the shaft/bearings. Shutting the motor off when EGT's are above 400* can cause the oil on shaft/bearings to coke.
Do you have a EGT gauge?
Great reply! That's something I didn't know..... Ur comments are welcome unlike that other dick up there! I was just going off what I was told. But as we speak I finished up installing the "reman" turbo from Pensacola and it want build boost!!! Actuator works just no boost. Either the ring is stuck or there isn't one. NOT A GOOD DAY!
