Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 02-21-2011, 08:42 AM
nolan62's Avatar
nolan62 nolan62 is offline
Garage is empty, add now
nolan62 is starting off with a positive reputation.
Do I need a donut?
I put the EFI exhaust manifolds on my 86 300. I have an exhaust leak but it's small. I only hear it under load. I think it's here where it connects to the pipe.
See the black spot on the side of the engine?
I was wondering if I need the donut gaskets? Do these manifolds even use the donuts?
Thanks
Click the image to open in full size.
  #2 (permalink)
Old 02-21-2011, 08:49 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
Wait till the engine is cold, start it up and run out really quick and run your hand around the manifolds and feel for the leak. You will have a little bit of time before it gets to hot to touch.
From the picture, those manifolds do not use donut gaskets. If it's leaking on the pipe to exhaust manifold connection, all you can do is tighten it up some more, or take it off and re-position it to see if that helps.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 02-21-2011, 08:58 AM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a very good reputation on FTE.ri_truck_guy has a very good reputation on FTE.ri_truck_guy has a very good reputation on FTE.ri_truck_guy has a very good reputation on FTE.
bill.csisar
It's quite been a while since I've messed with those 300 EFI manifolds, but I don't remember all those extra nuts in between the flange and the manifold. It looks like that low hanging nut on the right side of that flange could be affecting your ability to tighten that side. I know that parts stores sell replacement stud kits. I'd consider investing in one of those.
__________________
Bill
12 F150 Fx4 Supercrew Ecoboost w/Max Tow
86 F150 4x4 5.0 H.O. w/Mass Air Conversion
10 Harley Davidson Electra Glide Ultra Limited 103ci
05 Harley Davidson Softail Deluxe 95ci
"Everybody has issues...some people's are just more interesting...."
  #4 (permalink)
Old 02-21-2011, 09:03 AM
arusty1's Avatar
arusty1 arusty1 is offline
2003 Ford F-250
arusty1 is starting off with a positive reputation.
Are you a cop?
Same thing on my 5 liter, I got some exhaust sealant from NAPA,
dropped the system in the front, applied sealant and reinstalled
after cleanin' up the threads on the studs. Used anti-seize on the
studs.
  #5 (permalink)
Old 02-21-2011, 10:20 AM
nolan62's Avatar
Thanks guys, I'll try all these. I do have to stick my hand in there quick. I gets hot quick. I'll see if I can get the studs out without breaking them. I've never seen exhaust sealant before but I'll certainly look for it.
Thanks!!!
  #6 (permalink)
Old 02-21-2011, 10:29 AM
arusty1's Avatar
2003 Ford F-250
Don't take the studs out, take the nuts off and clean up the threads.
I think you'll find the nuts that hold the flanged cup are brass, I swapped
mine out for steel I believe they're 7/16-20. I had to ask about the sealant,
they kept it behind the counter.
...Rusty
  #7 (permalink)
Old 02-21-2011, 12:07 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel is gaining momentum as a positive member of FTE.Blue Rebel is gaining momentum as a positive member of FTE.
No, there are no donuts in there.
Those nuts we see on the studs should get taken off, they are probably preventing you from tightening your exhaust up fully.
If you want, I know you can buy new studs from oreillys. If you can Id pull them old ones out and replace them w/ new ones. Heat the **** outta the manifold around the stud holes, they will turn out easier that way.
__________________
1989 F250 4x4, 351W, ZF S542, 4:10s, Upgraded to Dana 50 TTB front, 4" suspension lift 33" street, 38" swampers for when things get crazy!
1995 F150 4x4 Swapped in 351W MAF, 4r70w auto, 6" suspension lift, 35" tires, 4:10s, Daily Driver
1993 F350 4x4, 7.3L N/A, ZF S547, 4:10s
  #8 (permalink)
Old 02-21-2011, 01:01 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a good reputation on FTE.82F100SWB has a good reputation on FTE.
Those nuts we see on the studs are most likely part of the stud itself. Ford manifold studs have a hex in the middle between the 2 different threads. Odds are that side had backed out a bit at some point in time and hasn't threaded back in.
Personally I prefer to replace the studs with Ford parts, as the manifold side is actually a tapered thread.
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
  #9 (permalink)
Old 02-21-2011, 02:06 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
82 is right. A couple of the manifold studs have backed off. The nut is part of the stud and should be against the manifold.
__________________
[/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
  #10 (permalink)
Old 02-21-2011, 07:38 PM
nolan62's Avatar
Yes the nut is part of the studs. I got replacements from RockAuto.
No they aren't backed out. They are screwed in as far as I could get them. I was afraid of breaking them off if I put anymore torque on them.
Dave's idea worked, Thanks. Cranked it cold and stuck my hand in there quick. I can feel it. I'm goin to take some air tools to it this Saturday. I appreciate it gemtlemen.
  #11 (permalink)
Old 02-21-2011, 07:46 PM
GLR's Avatar
GLR GLR is offline
Be careful with the air tools, you don't want to break a stud off in the manifold.
__________________
  #12 (permalink)
Old 02-21-2011, 07:53 PM
spurredon's Avatar
spurredon spurredon is online now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Spraying with PB Blaster and letting it soak over nite might make things come apart a little easier. You might have to shorten the studs od the manifold side so you will have more room to draw the flange tighter. Have you tried tightening them while they are hot? Be careful not to break the studs when you do this and not to get burned, but it might be all you need to do.
  #13 (permalink)
Old 02-21-2011, 11:13 PM
Blue Rebel's Avatar
I agree, i thought they came with nuts, but its been a few years since ive owned an I6, and i was unsure. But they are also correct in that those nuts should be up against the manifold. Those holes thread all the way through, w/o the nut there you should be able to keep screwing them in until they fall out the other side. Time/heat/corrosion may have gummed up the threads, tap out the holes before you put an impact on them, or pieces will come apart from togetherness.
__________________
  #14 (permalink)
Old 02-27-2011, 09:40 AM
nolan62's Avatar
My exhaust leak is now fixed. Thank you one and all!
I was very surprised that the manifold studs were much easier to screw in than when I first installed them. I did hit them with some Tri-Flow a couple of hours before. Anyway, I laid off the air tools and just put a 2 foot rachet on them. I got them screwed in all the way. I used a little high temp sealer for good measure and it's nice and quiet now. Well, quiet in the Cab. The Summit Racinf turbo muffler has a nice sound outside.
Tags
1997, 302, 97, diagram, donut, dounut, exhaust, f150, f250, ford, gasket, hot, manifold, stud, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
