Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 02-21-2011, 06:37 AM
iggy2's Avatar
iggy2 iggy2 is offline
Garage is empty, add now
iggy2 is starting off with a positive reputation.
What oil is in a new 6.2L?
Just read the owners manual and it seems that the oil they recommend is synthetic 5W20.
Does anyone know for sure if that is what the factory?
Does everyone with new 2011 6.2L use synthetic FMC 5w20?
Where do you buy your oil and filters? Walmart?
  #2 (permalink)
Old 02-21-2011, 09:37 AM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
2011 Ford F-250
My Garage
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
I'm guessing it would be Motorcraft semi-synthetic 5w20. That's what I used for my first oil change and will be using again. I'm also using Motorcraft oil filters.
You can use most any oil you want, just make sure it's 5w20 and at least semi-synthetic. Full synthetic is fine too. Filter quality seems to vary widely which is why I recommend sticking with Motorcraft.
__________________
2011 F250 6.2L XLT Crew Cab 4x4, 3.73.
Golden Bronze Clearcoat Metallic
2012 Coachmen Freedom Express 292BHDS
ARE Z Series Cap & BedRug
Audio upgrade
  #3 (permalink)
Old 02-21-2011, 11:05 AM
Mike in PA Mike in PA is offline
Mike in PA is starting off with a positive reputation.
At the dealership, Steve, the Service Manager told
me that my truck(2011 F-350 6.2L) came with the Motorcraft
5W20 synthetic blend and he was hoping
that I would stick with that same oil. I get
filters there at the dealership, $5-6 I believe, and
will be staying with the 5W20 blend.
Good luck with your new truck...
Mike in PA
  #4 (permalink)
Old 02-21-2011, 11:27 AM
iggy2's Avatar
So I guess it is the Motorcraft semi-synthetic 5w20 what I will use.
I know that Walmart has the Ford Motorcraft filter but next time I visit I will check on the Motorcraft oil.
Thanks for the information
  #5 (permalink)
Old 03-04-2011, 05:50 PM
iggy2's Avatar
Stopped by my local Walmart and found the Motorcraft semi-synthetic 5w20 in 1.25 gal container for $13 and the qt for $3.66 each. They also had the Ford oil filters. So I guess I will probably do my own oil changes.
Book say 7,500 miles but I plan on doing it every 5,000 miles.
FYI the 6.2L engine takes 7 quarts of oil.
__________________
2011 F250 6.2L
2012 Georgetown Motorhome Ford F-53 Chassis with V-10 (22,000lb chassis)
  #6 (permalink)
Old 03-04-2012, 07:58 PM
LazarusRising LazarusRising is offline
2011 Ford F-250
LazarusRising is starting off with a positive reputation.
Does anyone know which oil change interval applies? The manual says 7500, but my computer is telling me I still have 25% oil life left at 7600 miles. Which should I go by?
  #7 (permalink)
Old 03-05-2012, 01:26 AM
fz1dave's Avatar
Super Duty
2011 Ford F-250
My Garage
I'd change it at 7500, but I suppose it's open for interpretation if the computer says different.
__________________
Audio upgrade
  #8 (permalink)
Old 03-05-2012, 01:09 PM
akbash akbash is offline
2012 Ford F-250
akbash is starting off with a positive reputation.
oli change
My dealer suggested I change at 5000 mi and put a little reminder on the inside of the windshield.
  #9 (permalink)
Old 03-05-2012, 01:17 PM
RAPR's Avatar
RAPR RAPR is offline
2011 Ford F-250
RAPR is starting off with a positive reputation.
RAPR
I use 5W20 Mobil 1 full synthetic with a Mobil 1 oil filter. After 5000 miles, my truck still registered 50% oil life left, but I changed it anyways. I also installed a magnetic oil sump plug and a FilterMag filter magnet...I'm looking to keep my engine as contaminant free and long lasting as possible.
__________________
2011 F-250 CC - 6.2L, 4x4, 3.73, Lariat Ultimate Pkg, ReadyLift 3.5"Fx3.0"R lift kit, 35x11.5x18 Terra Grapplers
'Capital Campers', give your go some show
  #10 (permalink)
Old 03-05-2012, 07:11 PM
2011 Ford F-250
Thanks for your replies on my changing oil question. I was told by a service tech to go by the computer.
No disrespect meant, but Ford salesmen didn't even know the difference between cargo capacity and towing capacity when I bought my truck to carry a truck camper. Even the truck I finally bought says 3340 lbs. on the door sticker, but the camper slip in the glove box says 2400 lbs. I'm not towing anything, just carrying a camper on the bed.
So far the 6.2 L gas engine is a trooper at 7600 miles.
  #11 (permalink)
Old 03-06-2012, 05:31 PM
2011 Ford F-250
Oil Change today at 7950 miles, first one. This time tech recommended changing at 5000 miles with my camper load. HE says the computer does not account for load, speed, etc., just time, when keeping oil life percentage. Seems like there are many opinions on this. Its just another truck so I guess the conventional wisdom applies. The more frequent the oil changes, the safer you are. (Just costs a little more.)
  #12 (permalink)
Old 03-06-2012, 11:48 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Lightbulb
Quote:
I agree to a certain degree about some FORD sales folk. I was out test driving 2012 SD's over the weekend. A sales person told me straight up...that it was not possible to get a 6.2L with the 2-tone paint in Lariat trim. I did NOT challenge him on it...but knew he was completely wrong! eeek!
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #13 (permalink)
Old 03-07-2012, 07:32 AM
Byram's Avatar
Byram Byram is offline
Byram is gaining momentum as a positive member of FTE.Byram is gaining momentum as a positive member of FTE.
Quote:
biz
never listen to them... Back in '90 I went to order a Reg cab/4x4/4speed/460 F-250 - I had the money - knew the dealership, was gonna only negotiate $$ & purchase... Salesman said - you cannot get a 460 with 4x4! - I knew that was false. -- I walked -- Went to another dealer & gave them my money..
__________________
2011 F-250SC XLT
6.2; 3.73 EL; 4x4; BFG M/T 285's; B&W Turnover; Ranch Hand; Oasis XD 4000 OBA & Aux Battery; 5 Star assisted!
"Peace is that brief glorious moment in history when everybody stands around reloading".
  #14 (permalink)
Old 03-08-2012, 07:12 PM
biz4two's Avatar
Arrow
Quote:
Very true! At a different dealership...the sales guy told me the 6.2L in the F250 was the most powerful gas engine put in a F250. WTF??? Did this guy ever hear of the V10 3v gas engine???
IMHO...they need to study and learn the product.
biz
__________________
  #15 (permalink)
Old 03-08-2012, 08:19 PM
RZAR's Avatar
RZAR RZAR is offline
2011 Ford F-350
RZAR is gaining momentum as a positive member of FTE.
biz
That is somewhat true since you can't get a V10 in a F250 anymore.
__________________
2011 F350 4x4 RC 6.2 4.30
Tags
2011, 62, 62l, 67, engine, f250, filter, ford, motor, oil, qty, recommended, spec, specs, synthetic, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
