What oil is in a new 6.2L?
At 385hp, the 6.2L IS technically the most powerful gas engine ever put into an F250 from the factory. The 3v V10 Triton only made 362hp.
Where the V10 wins, is in torque, not power.
457ft-lbs for the Triton vs.405ft-lbs for the Boss
With that said, the 6.2L is at the beginning of its life cycle. The early V10 Triton made 310hp/425ft-lbs tq. Who knows what the 6.2L will put out once it has been around for 5+ years.
My 2 cents- I previously managed a local NAPA Auto parts store. I called Valvoline tech line about 5w-20 and was told that if it is not full synthetic, it is a blend. To make it to the specs they all make it that way. I use the NAPA branded oil (which is made by Valvoline) and have gotten along well. Also, I only trust Wix (and NAPA Gold ) Filters. After seeing several brands cut open, the difference is obvious! just my opinion!
[quote=biz4two;11540523]I agree to a certain degree about some FORD sales folk. I was out test driving 2012 SD's over the weekend. A sales person told me straight up...that it was not possible to get a 6.2L with the 2-tone paint in Lariat trim. I did NOT challenge him on it...but knew he was completely wrong! eeek!
I recently bought a 2012 F250 Lariat two tone copper with Gold trim! This does have the 6.2 in it and I love it. You can get one - just need to hunt!
Back to the main topic of the thread, Oil changes. If you guys are hauling with your 6.2's, which is what I do with the four SD's I own, I would recommend that you change the oil and filter every 3500 miles max. Cheap insurance, imho to make it last. Not sure about 6.2L yet but can tell you from experiance that the 5.4 3v just wont take oil changes every 5k and last you very long.
6.2
Just bought a new Ford f250 with the 6.2,,,plan on using Motorcraft 5-20 and the Motorcraft oil filters,,,believe the magnet on the outside of filter is a good idea,,,have a 2008 with 5.4 and have one on it,,,,after oil change I cut filter open and found a thin layer of sludge that no doubt had some microscopic metal particles,,,now the five quart jug of oil is 18.97 at WalMart and 25.99 at OReilleys
#30
jlillie
07-22-2016 06:56 PM
coolfeet
09-27-2015 11:59 AM
