Need VIN decoded - Ford Truck Enthusiasts Forums
Need VIN decoded
Old 02-20-2011, 08:37 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Need VIN decoded
Looking at a truck. All that is listed is crewcab, diesel 4x4 and vin. I need to know what trans is in it.
1FTHW26F7VEC00523
Thanks ,Brad
Old 02-20-2011, 09:43 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
I may be wrong, but I don't think trans info is in a VIN...
Old 02-20-2011, 09:54 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Heres all the info a VIN decode gives.
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class G, GVWR 8,501-9,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series - F250
Chassis Type: 4x4
Body Type: Pickup - Crew Cab
Engine Type - 8th Position:
Engine: 7.3(445cid) DI-Turbo
Cylinders: V-8
Fuel Type: Diesel
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1997
Assembly Plant - 11th Position:
Assembly Plant: Kentucky Truck: Jefferson County, Kentucky
Production Sequence Number - 12th - 17th:
Sequence Number: C00523
Old 02-21-2011, 12:32 AM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
The trans/axle/weight info will be given on the vehicle information label that can be found on the drivers side door jamb.
regards
rikard
Good to see the 21 Motorcraft win the 500
Old 02-21-2011, 04:20 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
You need the trans code from the door sticker as already stated. `97 was the last year for the E4OD, so if auto, it is probably that.
Old 02-21-2011, 05:55 AM
All right. Thanks guys. I found a truck on line and i cant call till at least 8am monday, i just wanted to know what trans it had
Old 02-21-2011, 06:45 AM
I found this web site and found out EVERYTHING
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, and Mazda Trucks VIN Decoder
And here is the info from the vin
EGAMK 4.09
EGAMD 4.10
TR0RK 5 SPD M/T Z/F S5-420
EJAJF 6250 LB(2834 KG) REAR AXLE ASY
EJAJJ 6340 LB(2876 KG) REAR AXLE ASSY
D2XE2 7.0 X 16" FORGED ALUM WHL
IBAAX AM/FM STEREO WITH SINGLE CD PLAYER AND SIX SPEAKERS
JCBAB AMBIENT LIGHTING
EM0C0 CALIFORNIA REQUIREMENTS
BLDAB CHROME-PLATED
AAMAB CONVENIENCE GROUP
D3MAD CONVENTIONAL SPARE TIRE
EJ1AB DECAL-4X4 PICKUP BOX
BSDAD DRIVER POWER MIRROR
EGLAB FORD/VISTEON AXLE VENDOR
CLFAE FRONT BUMPER-STEEL-CHROMED
CLVAB FRT LICENSE PLATE BRKT/HOLDER
DEBAF IMMERSION HEATER-ENGINE
AAGA1 KENTUCKY TRUCK PLANT BUILD
PNYCE LIGHT OPAL
EGJAC LIMITED SLIP REAR AXLE
BMLAE LOWER B/S MLDG
D3JUE LT235/85R-16E BSW A-T TYRES
FMLAB MAN TRANSFER CASE AND MAN HUBS
AC0B0 MANUAL AIR CONDITIONER
000YD MEDIUM OPAL GREY
PNFJA MEDIUM TOREADOR RED
EN0DS NAVISTAR 7.3L OHV DI TC V8 DSL
F7THB NOT DEFINED
BSFAD PASS POWER CONVEX MIRROR
B2GAE PRIVACY GLASS
CLMAE REAR BUMPER-STEEL STEP-CHROMED
BYBAE SECOND ROW BENCH SEAT (3 PASS)
FMNAB SKID PLATES
B3HAD SLIDING REAR WINDOW
GTDAB SPEED CONTROL
A9CAB STYLESIDE BOX - STL INNER/OUTER
HGAAB TACHOMETER
BYCAB THIRD ROW BENCH SEAT
GRAAC TILT STEERING WHEEL
BYDAE WITH 4TH ROW BENCH SEAT (4 PASS.)
GBCAB WITH AUXILIARY FUEL TANK
CJDAB WITH BODY TU-TONE PAINT
BLMAB WITH BRIGHT HEADLAMP MOULDING
EGLAC WITH DANA AXLE
DWCAB WITH HANDLING PACKAGE
BHEAB WITH NOISE INSULATION PACK
DAAAD WITH SUPER ENGINE COOLING SYSTEM
AALAA WITHOUT SPECIAL EQUIPMENT PACKAGE
AAAAD XLT VERSION
Old 02-21-2011, 08:50 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Great link!
Old 02-20-2013, 09:15 PM
Nof1 Nof1 is offline
Nof1 is gaining momentum as a positive member of FTE.Nof1 is gaining momentum as a positive member of FTE.
Great site thx alot
Old 02-25-2013, 11:34 AM
FlagshipOne FlagshipOne is offline
FlagshipOne is starting off with a positive reputation.
attempting to determine if my vehicle originally came with a keyless entry option.
1FTHX26G5NKB93370
tHANKS
Frame VIN Location Diesel_Brad 1999 to 2016 Super Duty 2 01-19-2017 07:47 PM
04 ranger rebuild Diesel_Brad Ranger & B-Series 8 09-19-2015 07:02 AM
Al's Bed Liner DONE!!! Diesel_Brad 1973 - 1979 F-100 & Larger F-Series Trucks 37 03-21-2015 09:51 AM
Car Forum Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 2 11-03-2014 06:20 PM
In need of Factory tow Mirrors Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 13 06-04-2012 04:01 PM
Tags
1995, 1999, 73445cid, cooling, daaad, decoding, diturbo, engine, f350, ford, medium, opal, super, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
