deactivation of the Neutral safety switch. - Ford Truck Enthusiasts Forums
Old 02-20-2011, 08:04 PM
Jayme Duty Jayme Duty is offline
Jayme Duty is starting off with a positive reputation.
I was told that i need to deactivate my NSS or else my truck won't start after i get the 5-speed swap done. I am not sure where this is located or what it looks like. Any help would be great this is one of my last steps to get this thing rolling again.
Old 02-20-2011, 08:43 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Not sure where it is on an E4OD but just an idea, use it to make a dead man switch with it.
On mine, I used the clutch pedal safety switch. At least I don't need to step on the clutch to start it anymore either.
I've hidden a small toggle switch, when on, the truck will start, when off, it cuts power to the starter no matter what. I love it.
You should do the same with your NSS.
Old 02-20-2011, 11:33 PM
Longview Longview is offline
Longview is starting off with a positive reputation.
Do you know where the clutch safety switch is on an '86 with a t19?
I wouldn't mine dissabling mine so i don't have to step on the clutch pedal to start :P
Old 02-20-2011, 11:36 PM
It's under the dash behind the clutch pedal, you should see a small connector going to a small plastic box if I remember correctly.
Old 02-20-2011, 11:47 PM
And I just disconnect it? Or do i jump it over to itself?
Old 02-21-2011, 06:44 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
nss on a manual trans is on the clutch pedal. nss on an automatic trans should be on the shifter arm of the trans with the reverse light switch
Old 02-21-2011, 07:25 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
On the E4OD the NSS is incorporated into the range sensor on the drivers side of the trans.
If you look at the wire harness at the range sensor I would be pretty sure you need to cut the W/PK and R/LB wires and join them, either direct or using a switch as suggested.
Old 02-21-2011, 10:00 AM
Lazy K, are you sure it is the white/pink and red/lightblue, i was told elseware it was the two red wires. Does anybody have a wiring diagram for the E4OD. Also is there anyway to hook the reverse lights back up
Old 02-21-2011, 11:49 AM
The two red wires would be for the C6 transmission. The reverse light switch is also in the TRS so you should be able to cut those wires also and connect them to the reverse light switch on the ZF5.
http://www.ford-trucks.com/forums/99...-problems.html Here is a thread with a wiring diagram, including the backup lights.
Old 02-21-2011, 03:58 PM
thank you for the diagram that was just what ineeded, hopefully this thing is moving under its own power tonight.
Disabling airbags? Mountain-man 1999 - 2003 7.3L Power Stroke Diesel 14 04-04-2016 01:38 PM
airbag code 25 esten07 2004 - 2008 F150 2 12-12-2015 08:42 AM
1999 Ford Ranger alarm deactivation jerrydell7777 Ranger & B-Series 2 11-02-2014 07:21 PM
Smart key deactivation cs1 Electrical Systems/Wiring 3 05-19-2012 11:38 PM
speed control deactivation switch ?? guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 5 04-04-2011 11:21 AM
Tags
1989, 73, 97, auto, clutch, f250, ford, issue, neutral, reverse, safety, saleen, supercharger, switch, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
