87 F150 Starts by jumping solenoid but not by key, stumped - Ford Truck Enthusiasts Forums
Old 02-20-2011, 06:44 PM
77h0t_r0d_wrecker 77h0t_r0d_wrecker is offline
77h0t_r0d_wrecker is starting off with a positive reputation.
Just as the title states, I can run the truck by jumping the posts on the solenoid, but not by turning the key. For some reason the small wire that activates the solenoid isn't doing it's job. For reference it's an F150 4.9L manual 4spd.
What powers that wire that excites the solenoid? Where does the wire come from? I tried tracing it but I lost it and i really don't want to unravel the whole harness. This is the only thing holding me back from driving the truck tonight after it being down for two months, any help would be greatly appreciated! Thanks in advance!
Old 02-20-2011, 07:12 PM
88n94 88n94 is online now
88n94 is gaining momentum as a positive member of FTE.
The power to that little wire comes from the ignition switch when it is held in the START position. If you run a jumper from that little post that that little wire hooks on to the large solenoid post farthest from the battery, will the engine spin over?
Old 02-21-2011, 05:56 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I think the start wire goes through the clutch switch too. Something else to check, at least.
Old 02-21-2011, 06:28 AM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
do you get power to everything when the ignition is on?
if you do just run a couple wires to a push button
Old 02-22-2011, 11:11 AM
Well I found the problem guys, thank you for the responses.
It turns out that the main ground that bolts to the frame before going to the block was totally corroded and mangled. I made up a replacement for that, still no fire. Then I pulled the starter (again, I had just done the clutch which sucked badly) bench tested; she tested fine, I cleaned all connections including the mounting points to get a good ground; still nothing.
So finally I said screw this, took a battery terminal straight from the positive and ran it to the starter..... WE HAVE IGNITION! So I made up a new wire from solenoid to starter and everything is gravy now.
I suppose being in there and disturbing things just made the wires that were on their last legs go bad.
Again thanks for the advice!
Solenoid, starter or ignition?? fyredude 1999 to 2016 Super Duty 15 07-15-2016 02:56 AM
96' F350 7.5L ignition solenoid problems cityjack 1987 - 1996 F150 & Larger F-Series Trucks 3 03-27-2016 08:45 PM
1984 F150 Trouble SwampFox112 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 11-14-2015 07:18 PM
78 F150 Starting Issues Wooticus 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2013 12:57 AM
98 F-150 won't crank Bueller 1997 - 2003 F150 9 05-03-2011 09:57 PM
Tags
1996, 1997, 86, 88, diagnosis, f150, ford, jump, jumping, key, selenoid, solenoid, solonoid, start, started, starts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
