2002 Ford F350 ... ALARM RESET BUTTON LOCATION? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-20-2011, 04:27 PM
JohnnyC3 JohnnyC3 is offline
JohnnyC3 is starting off with a positive reputation.
Exclamation 2002 Ford F350 ... ALARM RESET BUTTON LOCATION?
Hi fellas,
I've got a 2002 Ford F350 Gas V10 engine and my battery went bad, I took it out for about 16 hours (overnight) and I just bought a brand new one, I am trying to connect it but everytime I do, I set off the alarm.
I cannot turn off the alarm!!!
My remote got damaged & lost by the last friend I let borrow my truck (don't ask), so I've tried using the key to lock/unlock the doors manually, start the truck in the ignition but nothing works because the alarm keeps going off.
I am told there is a RESET button somewhere, I'm pretty sure it's a stock alarm system.
I can't find the reset button however. I opened the fuse box (under the steering wheel) and see all the fuses but no button, I'm really not sure what it looks like and where it's located.
Anybody can help me find what i'm looking for? Wish I hadn't ever lend the truck out, I'd still have the remote if so.
Old 02-20-2011, 04:33 PM
1buzzbait's Avatar
1buzzbait 1buzzbait is offline
1buzzbait is gaining momentum as a positive member of FTE.
Johnny--im afraid the vehicle does not have a "factory alarm" or "pats" either--the reset on an aftmkt sometimes can be found near the e-brake--ya may even find an odd looking module up in there--that would be the aftmkt alarm module--- good luck!
Old 02-20-2011, 04:37 PM
****! This isn't good at all.... any other suggestions? all I see is fuses down there, no buttons....
Old 02-20-2011, 05:14 PM
1buzzbait's Avatar
i gots no electrical knowledge bout aftmkt alarms--if its an ignition cut-out--i dont think you can disconnect any odd lookin wires from the batts terminals?? maybe sumone else will chip in!!!
2005 F-250 Won't Start LiquidxDIAMONDZ Electrical Systems/Wiring 1 06-29-2015 01:32 PM
Dealer Installed Alarm? tractoman 1994.5 - 1997 7.3L Power Stroke Diesel 1 05-22-2014 10:56 PM
Need assistance programming new key fobs w/aftermarket alarm F350SDKammyo 1999 to 2016 Super Duty 0 10-24-2013 02:19 PM
Alarm/Remote Question paulcalif 1999 to 2016 Super Duty 6 01-17-2011 12:47 AM
Alarm problem 63DH8 6.0L Power Stroke Diesel 8 12-24-2008 12:56 AM
Tags
1999, 2002, alarm, duty, f150, f250, f350, ford, fuse, number, reset, resetting, security, start, super, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
