IPR pigtail/connector - Ford Truck Enthusiasts Forums
Old 02-20-2011, 03:56 PM
dwt2011 dwt2011 is offline
dwt2011 is starting off with a positive reputation.
Have a 2003 F250 w/ the 6.0 and found that the connector to the IPR sensor is damageged. Does anyone know if you can buy just the connector or pigtail to replace this?
Old 02-20-2011, 05:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you sure can... the dealer will more then likly tell you no you cant get it...
there was a recall on the LCF in either 05 or 06 that list the part number I posted it before .try the search function.
Old 02-20-2011, 06:33 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Ford: 6E7Z-14S411-A
International 1878512C91
Old 02-20-2011, 06:34 PM
cheezit's Avatar
mark thanks for that I was to lazy to go dig up that tsb again.
hey just on the off chance do you have a part number for the eot/ect connectors?
Old 02-20-2011, 06:44 PM
bismic's Avatar
No I don't - sorry.
Old 02-20-2011, 10:23 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Actually, the correct part number for a wiring pigtail connector for the IPR valve and VGT solenoid is 6E7Z-12A690-DA. If you have an old 7.3L UVC harness kicking around, one of the injector connectors will work as well.
Old 02-20-2011, 10:37 PM
bismic's Avatar
Quote:
Thanks Mike - I know better than question you on the part numbers, that's for sure!
Do you know what connector 6E7Z-14S411-A is for (KIT WIR ASY PIG TL)? That way maybe I can track down where I got cross-ways w/ the numbers.
thanks,
mark
here is my link to the wrong part number .....
http://www.ford-trucks.com/forums/72...r-pigtail.html
did I mis-read what bowtiehatr posted?
Old 02-20-2011, 11:00 PM
m-chan68's Avatar
thanks,
mark
We are both correct. 6E7Z-14S411-A supercedes to 6E7Z-12A690-DA which makes absolutely no sense at all. 14S411 is the basic part number for all wiring pigtail connectors. 12A690 is the basic part number for glow plug wiring harnesses. The 6E7Z is the prefix that denotes 2006 model year LCF truck.
Old 02-20-2011, 11:03 PM
bismic's Avatar
Interesting .
Old 05-17-2014, 11:20 PM
kayooh kayooh is offline
kayooh is starting off with a positive reputation.
I bought a new ICP for a 2003 6.0. The pigtail that came with it is not color coded!
Is there a sure way to find out which wire goes where?
Old 05-17-2014, 11:30 PM
cheezit's Avatar
Yes look at it and splice one wire at a time
Old 05-18-2014, 08:17 AM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
Quote:
What Cheezit said! I did mine yesterday and 1 at the time is the way to go!
Old 05-18-2014, 08:41 AM
Paulsf350sdcc's Avatar
Paulsf350sdcc Paulsf350sdcc is offline
Paulsf350sdcc is starting off with a positive reputation.
When you guys do this splicing what type connectors do you use? Is there a heavy duty version worthy of the environment under the hood of these beasts!? :-)
Or do you just use what they have at the local parts store (oreilly, autozone,...)
Paul
Old 05-18-2014, 08:53 AM
cheezit's Avatar
I use a bullet crimp that has no plastic on it. Use a quality crimping tool like kd, Klein or channel lock. Not the one that look like the radio shack junk.
Use heat shink to cover each splice and then tape the repair. The oem kit should have all you need except the crimping tool.
Old 05-18-2014, 09:12 AM
Cheezit do you solder the connections?
need help finding a wire connector plug PIGTAIL birddogcrazy 1999 - 2003 7.3L Power Stroke Diesel 9 08-08-2016 04:32 PM
FICM Connector repair-with pigtail??? wabassguy1 6.0L Power Stroke Diesel 7 03-14-2016 06:05 PM
IPR pigtail wiring, matters? Rippin6Gears 1999 - 2003 7.3L Power Stroke Diesel 8 01-17-2016 11:53 AM
Injector Coil/Pigtail Shaneb75 6.0L Power Stroke Diesel 15 07-16-2014 09:51 PM
ipr pigtail dirtworker 6.0L Power Stroke Diesel 7 04-09-2008 12:35 PM
Tags
60, 73, buy, connector, connectors, diesel, ford, ipr, jersey, pigtail, pigtails, places, powerstroke, trucks, vgt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
