IPR pigtail/connector
All is not lost however as the connector is a Bosch "Kompakt 1.1A", specific part# 1 928 403 874, and it uses BDK 2.8 terminals
http://www.bosch-connectors.com/bogs...9/product/1473
Alliant Power makes up these pigtails and they are available through multiple local & online retailers, for about $28.00. Use there "dealer locator" to find a local retailer.
Part# AP0056
Home - Your Diesel Parts Distribution Network | Alliant Power
Hope this helps
Late to this party, but hope this helps anyone looking for the EOT/ECT sensor connector. After speaking at length with two different parts guys at two different Ford Dealerships and checking the Motorcraft "Wiring Identification Connector Guide" Ford does not sell this part. Ford's answer is to replace the wiring harness (go figure).
Part# AP0056
Hope this helps
Part# AP0056
Hope this helps
Tried to rep Cheezit and Bismic also but I must find others first.
The GM part will work if you break of a tab. I had that pigtail and confirmed it. However, I thought, "why do I want to jerryrig it when I can get the correct part",.do I turned it and offered the right part.
On the ipr and vgt pigtail, do the part numbers you listed contain the metal retainer or are they the plastic pigtails. I understand ford does not offer the metal retainer like is on the oem wiring harness. To get that metal retainer, you have to order an alliant. Please confirm our deny.
IPR / VGT Soleniod Pigtail Connector Repair Kit 94-07 - Riffraff Diesel Performance
Anyone know if this will be a good buy for on 2003 6.0 IPR pigtail?
Does IPR connector = IBPV solenoid connector?
Hey all, new here and to all of this. I just replaced the turbo and pedestal on my 2000 7.3 PowerStroke. In the process I broke the IBPV connector. I read elsewhere that this is the same connector as the IPR connector. I have not been able to confirm that, so I am wondering if anybody can give me a second opinion?
As an aside, the truck now has a lot more power, but is running real rough, as though it isn't hitting on all cylinders. No joke, sadly. As I understand it, this sensor should not cause such a problem. Is there something I could have knocked loose in my attempt. Runs rough even without the turbo engaging.
Thank you!
Wife's mad at me now, chris lund
Thank you!
Thank you!
Thank you!
#28
I am a little surprised that Cheezit does not solder his splices. When I first started working at Ford I got called down by the lead mechanic for useing crimp splices.
I was fixing to repair a harness and he saw me gathering my box of crimp connectors and tools and he walked over and said. Son you work for Ford now we dont crimp anything we solder connections. At first I thought he was just razzing the new guy but he was also repairing a harness at his work station. Not a crimp type connector anywhere. Just a soldering iron heating and some solder. He didn't even have any crimp pliers in his tool box.
Maybe it was just the way I was taught he made it seem like it was Ford policy.
I been soldering them eversince. I will admit in my later years I cheated. There are companies sell unisulated connecters with solder allready in the connector. Just trim your wire ends slide a piece of heat shrink on one wire stick the ends in the connector and hit it for a couple of seconds with a pencil torch. After it cools slide the heat shrink over and shrink the tube. Done wrap with tape and be gone.
birddogcrazy
08-08-2016 03:32 PM
Rippin6Gears
01-17-2016 10:53 AM
NotURMailman
1999 to 2016 Super Duty
12-04-2015 07:33 PM
HaydenFryGuy
09-21-2015 07:16 PM
