302 valves rattles at highway speed ?
Old 02-20-2011, 02:36 PM
restoringmy46's Avatar
restoringmy46
restoringmy46 is offline
I have a 79 with a 302 with the original 2 barrell carb. The carb started acting up so I took it apart and cleaned it. Now the valves rattle when it shifts into high gear and at steady highway speed. it doesnt do it any other time. Do I need to adjust the carb some or what. I hate to mess with it to much because it runs great but I want to get the valves right. The motor never done this before I took the carb off so I know its something I have done. I'm not a real good carb guy but I will try anything if you guys can help me out. Thanks Scott
Old 02-20-2011, 03:45 PM
planehunter's Avatar
planehunter
planehunter is offline
What valves are talking about?
Old 02-20-2011, 06:52 PM
restoringmy46
Valves in the heads or it might be the lifters. It didnt do it until I took the carb off and cleaned it.
Old 02-21-2011, 05:39 PM
planehunter
What you're hearing is 'ping' (pre-ignition) which is not good to hear. Could be because of the rebuild you are running the carb leaner, which will cause the ping, or the timing is off. Check timing first, then look at maybe backing the idle screw out a bit. All vacuum hoses correctly hooked up?
Old 02-23-2011, 08:26 AM
bashby's Avatar
bashby
bashby is offline
pinging aka detonation aka valve rattle (thats a really misleading term) while under light throttle can be caused by too much vacuum advance. Check base timing first as suggested above. If thats ok try unhooking the vac advance, plug the hose and drive it. Adjusting the idle mixture richer to compensate for a lean higher rpm condition wont work... it would have to be way rich at idle.
Old 02-24-2011, 10:32 AM
restoringmy46
Thanks for the help. I'll check the timing tomorrow. I really think its the carb because it didnt do any of this untill I cleaned it. I will check it out and get back with you guys. Thanks again. Scott
Old 02-24-2011, 11:17 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
the carb needs readjusted since the rebuild.
Old 02-24-2011, 11:12 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
Did the truck originally have an EGR valve and is it hooked up? I've seen cases of severe pinging on carbed vehicles that were traced back to a non-operative EGR valve. If the carb is jetted and calibrated for use with an EGR valve, it will run too lean without one.
Old 02-28-2011, 03:40 PM
jaye's Avatar
jaye
jaye is offline
Mine was doing that util I switched to a higher octane fuel; I also would add octane boost if I filled up with regular.
Old 03-13-2011, 10:33 AM
restoringmy46
I put 93 octane in it and played with the timing. Its helped some but not stoped it. I'm going to set the timing back somemore and see where that gets me. Scott
Schnurrbart
28
03-11-2017 07:55 PM
yankeerebel
11-22-2016 02:20 PM
axelgawn
01-29-2016 08:41 PM
Mdc9966
15
11-12-2015 11:51 AM
calzone
1978 - 1996 Big Bronco
23
08-30-2006 11:20 AM
Quick Reply: 302 valves rattles at highway speed ?
