Axle code D5 - Ford Truck Enthusiasts Forums
Axle code D5
Old 02-20-2011, 11:52 AM
scottw1 scottw1 is offline
scottw1 is starting off with a positive reputation.
Axle code D5
My 1995 F350 DRW 7.5L has a axle code D5. What gear ratio is that a code for?
Old 02-20-2011, 11:56 AM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
if it ends in 5, it's a 4.10
if it ends in 8, it's a 3.08
if it ends in 9, it's a 3.55
Old 02-20-2011, 12:24 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
D5- Ford Sterling 10.25 dual rear wheel 4.10 with limited slip diff (7400 rating)
Old 02-20-2011, 12:50 PM
skyfox10's Avatar
You and your stupid superior answer...
Old 02-20-2011, 12:56 PM
Quote:
Call me stupid but what does the 7400 rating mean?
Old 02-20-2011, 02:33 PM
skyfox10's Avatar
If I had to guess, I'd say that it was the maximum weight it could support.
Old 02-21-2011, 05:03 PM
Yea that's what the axle is rated to withstand as far as a total load goes. That number is also helpful when ordering rear springs and some of the axle and break components. Just like with a F250. Knowing if you have a D44HD or a D50 when ordering bearings, axle joints. Ect.
Yes I know most of my responses and answers are stupid. I get told that a lot. Sorry.
Old 09-12-2013, 11:00 AM
infinite-foamies's Avatar
infinite-foamies infinite-foamies is offline
infinite-foamies is starting off with a positive reputation.
does the torque rating change with the axle?
1991 F350 "D5N" axle code??????? Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 09-22-2014 06:47 PM
Axle codes 35, 45, 65 Rico47635 1987 - 1996 F150 & Larger F-Series Trucks 5 11-30-2011 03:16 AM
Axle code richard stone 2004 - 2008 F150 2 05-27-2010 09:28 PM
Axle Code D9? f100beatertruck 1999 to 2016 Super Duty 8 03-07-2010 07:46 PM
Front Axle Code hokie93 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-28-2009 09:51 PM
Tags
1989, 1995, 44, axle, code, d5, differential, dual, f350, ford, rear, refill, truck, wheels, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
