Can this be my starter?
Old 09-11-2013, 10:21 PM
wyomingbs's Avatar
wyomingbs
wyomingbs is offline
97 f250 HD 460, 5spd
My truck has been slow to start a couple times. Twice friends have asked if my battery is going. I had the battery checked twice, once a few weeks ago and both times it was good, I think 12.98.
Just now I had my engine off but the headlights on for maybe 1 minute. Then when I restarted it was the slowest it's ever been. It was like starting up when it's 20 below out, probably worse, took forever but it did start.
A mechanic here tested my battery awhile ago and when I started up the truck he said it sounded like the starter was going. Truck has 74k, I've had it since 54k.
Just looking for your ideas.
Old 09-11-2013, 11:09 PM
jaagen's Avatar
jaagen
jaagen is offline
I would first check the alternator to be sure that it's charging the battery properly, Next I would have the fuel pressure checked along with the fuel pump. I can safely assume your have dual tank. Does the truck act the same no matter what tank you use? Does the starter make any other noise than not starting at second to third crank? At some auto parts stores they can test the starter.
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
Mine did the exact same thing when the starter went out. My battery was good, jumping it didn't help & it would run the winch just fine. It just started cranking slower & slower till eventually it did nothing when ya turned key. It would start fine if you parked on a hill & popped the clutch when it got rolling.
Old 09-12-2013, 10:37 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
With any electrical problem the first thing to do is make sure all connections are clean and tight.. This include battery cables both at the battery and the other end of the cable...
I'm not saying you don't have other problems, but if the cables are loose or corroded at any point , they will have you chasing your tail forever.
Old 09-12-2013, 10:57 AM
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
Good point on the cables & connections. I had just done the 3g upgrade & replaced all my battery cables so was pretty sure mine were good.
Tees77f150
15
06-27-2022 04:53 PM
Troy conrad
1999 to 2016 Super Duty
06-23-2019 11:09 PM
1badshovel
01-22-2013 06:28 PM
Wakeboarder141
1978 - 1996 Big Bronco
04-25-2005 06:56 PM
cnolin
10-02-2003 05:49 PM
Quick Reply: Can this be my starter?
