Really need some help with this F-250
My problem is this...I was driving my truck a few weeks ago and it started loosing power and missing and wouldnt go over 5 mph so I pulled over shut it off and put more gas in it and it has been fine ever since till a few days later it wouldnt start. About a week later it randomly started again and I have been driving it ever since but today it started missing and violently jerking when accelerating again. I replaced the ignition control module thinking that was the problem but obviously it wasnt and it is doin the exact same thing again. Any help?
Thanks
Thanks
Received 3,107 Likes
on
on
yup. try a clean filter again. if it clears up for a while and comes back, i would suspect fuel "additives"
a neighbor had a similar experience with his chevy. someone put styrofoam packing peanuts in his tank. it screwed the whole system up. it took 2 weeks to get everything cleaned out.
on
I have the same truck, same year, same engine, my truck was doing the same thing, I thought it was a fuel pump, it bench tested fine. The problem was intermittent, some mornings the truck would fire up right away, others I would have to crank it and crank it till it would start. I replaced the fuel pump relay and the ecu relay on the driverside inner fender and the problem stopped. Just a thought, check it out.
davidalan1731
12-09-2010 02:48 PM
I8URCAT1
11-14-2008 12:17 PM
