what year is my block?
02-19-2011, 09:58 PM
on
the numbers on the bottom of the block are ...
D2ae-6015-ba-15
2a28
thanks for any help.
02-20-2011, 05:42 AM
on
local performance shop could be able to tell you.
02-20-2011, 06:27 AM
It's somewhere between 1972 and whenever they next changed the block casting numbers.
02-20-2011, 08:30 AM
Is this the # on the flat pad along side the oil pan rail where the starter mounts?
02-20-2011, 10:12 AM
on
yes it run next to the oil pan on the bottom, theres another number near the water pump but i was told not to use that one?
02-20-2011, 10:18 AM
Quote:
Originally Posted by
Cody_302
D2ae-6015-ba-15
2a28
January 28th, 1972 Unless you think it came from 1982. And that can be figured out by looking at the flat surface on the top backside of the block where the VIN is partially stamped.
02-20-2011, 10:20 AM
on
well the truck it was in was a 72 so im guessing its the org block.
02-20-2011, 10:24 AM
Probably so. If the truck is still there, you can look at the vin, and then find the same number on the block on the back.
02-20-2011, 10:28 AM
on
alright ill take a look i dont have them numbers down yet.
Badass56
04-17-2018 10:19 AM
Mayberry
2017+ Super Duty
37
10-05-2016 09:34 AM
Hammer40330
1999 to 2016 Super Duty
16
05-09-2016 08:42 AM
fordeverpower
06-18-2010 02:28 PM
ilikefordtrucks
09-15-2004 04:23 PM
302 ,
351 ,
351w ,
6015 ,
aa ,
block ,
blockwhat ,
casting ,
d2ae6015aa ,
d2ae6015ba15 ,
f4e ,
ford ,
number ,
windsor ,
year
