speaker pop
Old 02-19-2011, 09:55 PM
dcciie251's Avatar
dcciie251
dcciie251 is offline
speaker pop
Got to work this morning after running the defroster on high, turned the key off and the speakers popped, like a static discharge or a high-power amp powering up. I turned the key back on and off several times and it still happened. Started it up to come home and everything was normal. Got home after running the defroster on high all the way and the problem happened again.
After the truck cab cooled off the problem went away again???? It almost seems like the radio was getting too hot. I did a search and only one thread had the word speaker.
2008 f150 4x4 4.6 am/fm single cd factory radio
Old 02-19-2011, 11:23 PM
2007F150FX4's Avatar
2007F150FX4
2007F150FX4 is offline
My 07 does the same thing. Sometimes it will do it everytime I shut the truck off and other times it can be months in between it doing it.
Being in the desert I only use the defrost a few times a year so I dont think its related.
Do you happen to have the factory Ford power code alarm with remote start?
I have the factory radio with the 6 disk changer MP3 aux input stock speakers.
Old 02-20-2011, 06:40 AM
shorebird's Avatar
shorebird
shorebird is offline
Old 02-21-2011, 09:29 AM
JoSHN's Avatar
JoSHN
JoSHN is offline
09-20-10*** SPEAKER POP AND/OR RADIO INOPERATIVE/BLANK/LOCKED UP
This TSB should help. It's the radio and the use of the heater on high settings.
Raptr241
02-28-2020 12:12 PM
chamblizi
11-04-2012 06:51 PM
TallPaul
15
08-06-2009 08:39 PM
james734
04-28-2008 01:53 PM
Quick Reply: speaker pop
