no brake lights
02-18-2011, 11:24 PM
on
no brake lights
got no brake light got tale light
02-19-2011, 01:13 AM
With the immense amount of information you've given us we should be able to pinpoint the problem with precision accuracy.
What year is your truck?
Have you checked your fuses?
Have you checked the bulb?
Are the blinkers inside the truck blinking rapidly?
Is it on one side or both?
Did you really think that with "got no brake light got tale light" we were going to be able to give you good advice?
02-19-2011, 03:40 AM
on
98 ranger good bulb both side
02-19-2011, 07:39 AM
brake pedal switch. blown fuse. bad multi-function switch. do turn signals work?
02-19-2011, 08:17 AM
on
Quote:
Originally Posted by
big red ranger
since we are "playing the lets see if we can guess the problem but only get one clue at a time GAME"............I am going to go first..............I bet you have a 5 speed manual transmission?........
02-19-2011, 08:43 AM
Did you check your fuses like I suggested?
02-19-2011, 12:19 PM
on
brake pedal switch good. turn signals work
02-19-2011, 12:33 PM
on
big red ranger
What would Nostradamus do?
02-19-2011, 01:10 PM
on
02-19-2011, 01:12 PM
on
03 Maz B23
Take to dealer. He fix.
Me agree.........dealer nice man......... no charge much...........feed family good....
02-19-2011, 01:16 PM
on
02-19-2011, 01:29 PM
on
03 Maz B23
He fix tale lit quick.
there is nothing like setting yourself up for failure like walking into a Dealer and saying........"car here, you fix, me come back later"
02-19-2011, 01:32 PM
This is useless. Drive around with no brake light, I don't care
02-19-2011, 08:22 PM
You're probably low on brake light fluid. The fill point is under the hood, right behind your flux capacitor.
02-20-2011, 06:27 AM
bad multi switch
Reason: trying to simplificate and add lightness
