1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
To use gasket sealant or no gasket sealant on transmission oil pan
Old 02-19-2011, 06:23 PM
Oppland's Avatar
Oppland
Oppland is offline
The "reusable" transmission oil pan gasket on my 4r100 tranny doesn't look so reusable so I picked up an aftermarket Fel-Pro gasket. As far as I know Fel-Pro in general recommends that no gasket sealant be used with their gaskets, although I have not called them and confirmed this for this particular gasket--it's just an educated guess as it is not one of those cheap cork gaskets but the nice rubber type. What do you think? Should I make a gasket sandwich and use sealant and the gasket or just use the gasket dry? Either way I will torque the tranny oil pan bolts to 11 lb-ft per the manuals instructions.
Also, the manual says nothing about using thread sealant on any of the bolts. I was wondering whether a little thread sealant on the drain bolts like the torque converter and the tranny oil pan wouldn't hurt? In general I do what the manual says--I don't want to screw anything up.
Old 02-19-2011, 06:29 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
No gasket sealant or thread sealant necessary. You can do either or both for peace of mind, but personally I wouldn't bother.
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
Per my experience all the gasket + sealant do is a mess.
Cork gaskets did like to be glued to one side what was different story.
Old 02-19-2011, 06:53 PM
Oppland's Avatar
Oppland
Oppland is offline
Good to know, thanks for the reply.
Old 02-19-2011, 07:07 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
No problem, and welcome to FTE!
Old 02-19-2011, 08:37 PM
houstonmr's Avatar
houstonmr
houstonmr is offline
I have been told never to use gasket seal on automatic transmissions since little pieces of the sealant can get into the valve body and cause trouble.
Old 02-19-2011, 11:10 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
A light amount of tack on the pan side to hold in place is a good idea. May depend on the gasket and how much distortion it has if any.
Old 02-20-2011, 04:55 AM
spinella's Avatar
spinella
spinella is offline
fel pro makes a product called high tack. you spray that on the gasket. i bought a oem gasket (did'nt use it... re-used my old one)and it says to install dry. i did w/ no problems.
http://shop.advanceautoparts.com/1/1...art-80065.html
Old 02-20-2011, 06:43 AM
m350's Avatar
m350
m350 is offline
I reused the pan gasket on my 06' F-350, TS trans,,,clean it, wipe all down, re-installed it,,,,does not leak a Drop ! there are re-useable !
Old 02-20-2011, 08:23 AM
bucci's Avatar
bucci
bucci is offline
High Tack
That's what I use too. I have an older bottle with a brush in the cap and it's purple. Works very well.
Old 02-20-2011, 09:20 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
No stuff! If you absolutely must use something just use high tack on one surface to hold the gasket in place. If you use any sealant with the rubber seal it can actually make the rubber seal slippery and push it out from between the pan and the trans making a leak. I have seen this happen to people with oil pan gaskets. They want to do a good job so they make a mess all over with rtv trying to do the right thing and then the rubber gasket gets squeezed out when they tighten the bolts but they don't see it. They fill the car with oil and lo an behold oil is pouring on the ground.
Not only that but any extra "glue" like mentioned will squeeze out and can clog up filters, screens, pump, etc. It is very important that even when you DO have to use rtv is to only use enough to do the job. When the parts are bolted together there should be minimal and an even squish of rtv out from between the parts like in the pic below of the rear end cover for my X. I have seen oil pick up screens nearly completely blocked off from excess rtv being use on oil pans.
Old 02-20-2011, 09:30 AM
offroadnt's Avatar
offroadnt
offroadnt is offline
I use either gaskets or silicone never both, unless called for at seams etc. in the manuals, then I just apply a dot. Some manufacturers also recommend you coat gaskets with oil (Chelsea and Muncie PTOs come to mind).
Matt Wilson
39
08-17-2019 08:05 PM
Nitro901
01-06-2017 11:35 AM
bigfish6025
06-27-2014 05:39 PM
pawpaw
1983 - 2012 Ranger & B-Series
17
04-26-2014 08:52 PM
gthbryce
15
04-20-2009 11:53 PM
Quick Reply: To use gasket sealant or no gasket sealant on transmission oil pan
