TFI Module - Ford Truck Enthusiasts Forums
TFI Module
Old 02-19-2011, 03:28 PM
Bovaloe's Avatar
Bovaloe Bovaloe is offline
Bovaloe is starting off with a positive reputation.
TFI Module
Does the distributor mounted TFI Module need to be tight against the distributor body, like a good electrical connection?
Both the threaded holes on the body are stripped out so I cant tighten them. I was going to get a bit longer bolt and put a nut on the back side of the hole I can. The other bolt stays in the hole just wont get tight. Would this cause any problems?
Old 02-19-2011, 05:27 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
There is no electrical connection between the TFI and distributor mount. The mount acts as a heat sink. A poor mechanical connection between the two can lead to the TFI module overheating and causing other issues. I would suggest making sure there is a good coating of thermal grease on the back side of the TFI before tightening it down.
Old 02-19-2011, 06:56 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Tap the holes out to a bigger size and screw it down.
Old 02-19-2011, 07:13 PM
Bovaloe's Avatar
Quote:
Like dialectric grease? Thats more for connections, what exactly is thermal grease?
Quote:
Yeah I was debating on that, Id have to go buy the right size tap though and Im trying to keep this cheap as possible since Ive dropped too much money in this pickup already
Old 02-19-2011, 07:19 PM
subford's Avatar
Another TFI cost a lot more than a tap.
Thermal grease is not Dielectric Grease. Thermal grease is for heat transfer and is white in color. Dielectric Grease is more or less clear and is for corrosion and to keep spark plug boots from sticking.
You can get Thermal grease at Radio Shack.
Old 02-19-2011, 07:21 PM
F-series Fan's Avatar
F-series Fan F-series Fan is offline
F-series Fan is starting off with a positive reputation.
The issue I fear has been described, save 1, Too much movement could cause it to catch inside spinning components and shred your Distributor guts (not good) I would follow the advice the others have already given.
Remote TFI gnd circuit insight? grego Electrical Systems/Wiring 9 05-09-2010 09:35 AM
tfi relocation kits broncobillyII86 Bronco II 4 01-14-2007 01:11 PM
TFI module idea. Will this work? Ian 84 BII Bronco II 8 04-15-2006 03:59 PM
Relocate TFI Distributor module 85 f-150 302 HowardH Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-12-2006 11:41 AM
TFI Distributor danlee Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 05-19-2005 07:20 AM
Tags
1991, 1994, 351m, 460, 87, buy, distributor, e4od, f150, f250, ford, module, support, tfi, tif
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
