1964 Ford F100 Steering column and gearbox
Old 02-19-2011, 01:17 PM
connvicted64f100's Avatar
connvicted64f100
connvicted64f100 is offline
Just bought a 1964 ford f100 and pretty much the only thing it needs is a new steering column and gear box. Any one know where I can get one. This is my first ford so I'm a little lost on where to get quality parts for it. Any help is appreciated.
Old 02-19-2011, 01:36 PM
garbz2's Avatar
garbz2
garbz2 is offline
Why does it need a column and steering box. Describe the means and it may be other things exasperating the issues.
Expect to pay 4 to 500 for a rebuilt box. The column can be rebuilt with available parts from ford or aftermarket.
Garbz
Old 02-19-2011, 02:24 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
While obsolete, all the internal parts of the M/S gearbox can be found NOS. Sometimes, only the steering shaft's bearings/races and sector shaft bushing need to be replaced to correct the 'play' in the wheel.
The upper/lower steering column bearings (2-C3DZ3517A) and sleeves (2-B1AZ3518A) are still available from Ford. Both the 3 speed manual & A/T shift collars have been reproduced.
If a 3 speed M/T, and the shift lever is binding up between 1st & 2nd, the parts (bushings/insulators) to fix this problem can also be found NOS (New Old Stock).
Old 02-19-2011, 04:11 PM
connvicted64f100
Somebody replaced the original steering column and gearbox with a newer model and it is WAY to long. I'm practically driving with my chest. Was looking for the original or one of very similar lengths. Sorry I wasn't more specific originally.
Old 02-19-2011, 06:54 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Jetcopterpilot is offline
Here is a link :
https://secure25.securewebsession.co...shop/index.htm
Give them a try!
Old 02-19-2011, 07:55 PM
garbz2's Avatar
garbz2
garbz2 is offline
You need to dive a bit deeper in to the truck and confirm it is a 64. Is the truck a Twin I beam or a straight axle?
Post the vin number.
The 61 to 64 steering box is an integral shaft type and nothing else remotely fits unless it was upgraded with a Toyota conversion.
Garbz
Old 02-23-2011, 10:22 AM
connvicted64f100
Can you elaborate a little more on the Toyota conversion? I'm stationed in Germany and the truck is with my dad as he is doing all the work for me while I am over here.
Old 08-07-2014, 07:46 PM
Ford64's Avatar
Ford64
Ford64 is offline
power steering
Hello, I was wondering if you were able to do the Toyota conversion for power steering on your 64 F100 and is so would you please share the details. I would really appreciate it.
Thank you,
Tyronza
Justin039
03-16-2017 04:06 AM
Ferari
18
12-06-2016 10:27 PM
hombre292
08-25-2016 08:17 AM
bjmayberry2
05-29-2016 12:33 PM
izzo
09-27-2015 11:53 PM
Quick Reply: 1964 Ford F100 Steering column and gearbox
