1964 Ford F100 Steering column and gearbox - Ford Truck Enthusiasts Forums
Old 02-19-2011, 01:17 PM
connvicted64f100 connvicted64f100 is offline
connvicted64f100 is starting off with a positive reputation.
Just bought a 1964 ford f100 and pretty much the only thing it needs is a new steering column and gear box. Any one know where I can get one. This is my first ford so I'm a little lost on where to get quality parts for it. Any help is appreciated.
Old 02-19-2011, 01:36 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Why does it need a column and steering box. Describe the means and it may be other things exasperating the issues.
Expect to pay 4 to 500 for a rebuilt box. The column can be rebuilt with available parts from ford or aftermarket.
Garbz
Old 02-19-2011, 02:24 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
While obsolete, all the internal parts of the M/S gearbox can be found NOS. Sometimes, only the steering shaft's bearings/races and sector shaft bushing need to be replaced to correct the 'play' in the wheel.
The upper/lower steering column bearings (2-C3DZ3517A) and sleeves (2-B1AZ3518A) are still available from Ford. Both the 3 speed manual & A/T shift collars have been reproduced.
If a 3 speed M/T, and the shift lever is binding up between 1st & 2nd, the parts (bushings/insulators) to fix this problem can also be found NOS (New Old Stock).
Old 02-19-2011, 04:11 PM
Somebody replaced the original steering column and gearbox with a newer model and it is WAY to long. I'm practically driving with my chest. Was looking for the original or one of very similar lengths. Sorry I wasn't more specific originally.
Old 02-19-2011, 06:54 PM
Jetcopterpilot's Avatar
Jetcopterpilot Jetcopterpilot is offline
Jetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputation
Quote:
Here is a link :
https://secure25.securewebsession.co...shop/index.htm
Give them a try!
Old 02-19-2011, 07:55 PM
garbz2's Avatar
You need to dive a bit deeper in to the truck and confirm it is a 64. Is the truck a Twin I beam or a straight axle?
Post the vin number.
The 61 to 64 steering box is an integral shaft type and nothing else remotely fits unless it was upgraded with a Toyota conversion.
Garbz
Old 02-23-2011, 10:22 AM
Can you elaborate a little more on the Toyota conversion? I'm stationed in Germany and the truck is with my dad as he is doing all the work for me while I am over here.
Old 08-07-2014, 07:46 PM
Ford64 Ford64 is offline
Ford64 is starting off with a positive reputation.
power steering
Hello, I was wondering if you were able to do the Toyota conversion for power steering on your 64 F100 and is so would you please share the details. I would really appreciate it.
Thank you,
Tyronza
Steering column and steering wheel Justin039 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-16-2017 04:06 AM
1964 F100 4x4 Ferari 1961 - 1966 F-100 & Larger F-Series Trucks 18 12-06-2016 10:27 PM
1964 F100 - Power Steering hombre292 1961 - 1966 F-100 & Larger F-Series Trucks 3 08-25-2016 08:17 AM
Steering column parts and availability help bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-29-2016 12:33 PM
Tonneau Cover for 64 F100 LWB connvicted64f100 1961 - 1966 F-100 & Larger F-Series Trucks 3 03-14-2011 05:46 AM
Tags
1964, 1980, 54, 63, 64, collar, column, f100, ford, gearbox, length, parts, schematic, steering, streringbox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
