Tranny won't go into reverse
2002 f350 w/ 7.3l, 4x4,extended cab long box..... Drove for 1/2 hour, went to back up, wouldnt go, noticed tranny temp guage almost to the yellow, still go's in drive, I checked the tranny fluid, was very low, added 3 litres still no reverse, no leaks under truck, when i put it in rev. It revs up as if it was in gear but no go, very confused! Plz help
It isn't possible to burn oil in the transmission. It has to be leaking somewhere. With the engine COLD check for oil in the coolant. A common leak point is the trans cooler inside the radiator.
Another thing to check is if the transfer case is overfilled. The seal between the trans and transfer case can fail and the trans will lose oil to the transfer case. The way to check this is to remove the fill plug on the transfer case. If about three quarts run out, that's where you lost your fluid.
stoven
04-22-2014 08:48 AM
sf76
12-02-2012 08:32 PM
skinsey
03-27-2004 12:44 AM
