Tranny won't go into reverse - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-18-2011, 10:39 PM
Horizon09 Horizon09 is offline
Horizon09 is starting off with a positive reputation.
2002 f350 w/ 7.3l, 4x4,extended cab long box..... Drove for 1/2 hour, went to back up, wouldnt go, noticed tranny temp guage almost to the yellow, still go's in drive, I checked the tranny fluid, was very low, added 3 litres still no reverse, no leaks under truck, when i put it in rev. It revs up as if it was in gear but no go, very confused! Plz help
Old 02-19-2011, 04:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
First off we can eliminate anything electronic. All the sensors and solenoids can't keep it from going into reverse. It's probably a seal in the reverse clutch, though it could be something broke in the reverse clutch, too. I would have to tear the trans down to be sure.
Old 02-19-2011, 06:59 AM
Does it sound right if the fluid didn't even show up on the dip stick that it would take 3 litres to fill it? Is it possible to burn that much fluid in three months time?
Old 02-19-2011, 08:33 AM
It isn't possible to burn oil in the transmission. It has to be leaking somewhere. With the engine COLD check for oil in the coolant. A common leak point is the trans cooler inside the radiator.
Another thing to check is if the transfer case is overfilled. The seal between the trans and transfer case can fail and the trans will lose oil to the transfer case. The way to check this is to remove the fill plug on the transfer case. If about three quarts run out, that's where you lost your fluid.
Old 02-20-2011, 09:33 PM
Thanx Mark.. That gives me some where to start... If it is the reverse clutch will i do more damage driving it to the shop?
Old 02-21-2011, 03:45 PM
My guess is that it won't cause any more damage.
92 f150 4x4 aod wont shift up from 1st Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 8 03-21-2015 02:51 PM
clunking into reverse and shuttering vibrations at highway speeds. stoven 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-22-2014 08:48 AM
2000 F150 4x4 5.4 4R70w Transmission No Reverse tulsatonyfan 1997 - 2003 F150 4 11-19-2011 11:40 PM
Occasional hesitation in reverse H1449-6 Excursion - King of SUVs 11 04-15-2009 02:51 PM
2007 f350 auto transmission slips sometimes going into reverse Robber80 1999 to 2016 Super Duty 3 12-05-2007 06:07 PM
Tags
2002, 2004, 450, 73, brake, f150, f350, fluid, ford, gear, lost, reverse, slow, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
