99 Xpediton, no power to the ac compressor - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 02-18-2011, 07:45 PM
tmajikman tmajikman is offline
tmajikman is starting off with a positive reputation.
I am not getting an power to my compressor, I have swapped the relay, diode and checked every fuse, I did jump the switch that was on the line on the passenger side front of the vehicle and I still could not get the compressor to kick on.
Does anyone have a link to the ac schematics?
Can anyone point me in the right direction as to where the low pressure/cycle switch is located?
Or does anyone know what path the ac system uses as far as what relay, pcm, fuses and such power up what other items in regards to getting the needed voltage to the compressor.
Any help would be greatly appreciated.
Old 02-19-2011, 10:57 PM
smac22 smac22 is offline
smac22 is starting off with a positive reputation.
Did you check the freon level? Mine shut off because of that...Just a thought
Also, the low side switch is the one you did the jumper on I believe...
Old 02-19-2011, 11:11 PM
I may have done the high side switch, I did somemore research and found out the low side switch is under the plastic cover by the battery and around all the wiring, I still need to jump that switch, thanks for the reply
Old 02-19-2011, 11:16 PM
yep, that's the one. It's on the accumulator. I bet it works when you jump it.
Old 02-20-2011, 09:21 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You'd do best to address HVAC issue is the HVAC forum. Start with the FAQs.
Old 02-20-2011, 10:04 AM
Quote:
I did, thats how I found out that in 99 the X has a low and high pressure switch, the low pressure switch was jumped for a few seconds and the compressor kicked on, so I either have low freon and a leak, or a bad low pressure switch, my bet is low freon and a leak :-(
Old 02-20-2011, 11:56 AM
Glad you got it to kick on! My leak was a slow one at the schrader valve on the low side. Make sure they are nice a snug. Hopefully its just the switch though
07 Expedition EL A/C Blowing Warm Air martyshel 2007 - 2014 Expedition & Navigator 2 05-07-2015 11:44 PM
1999 a/c power shartflhs Electrical Systems/Wiring 7 07-12-2013 07:50 PM
AC no power ggirten 1999 - 2003 7.3L Power Stroke Diesel 5 10-12-2011 06:13 PM
AC on 1996 F250 PSD bcalhoon 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-09-2011 05:35 PM
Does the A/C system have a relay or fuse? Where truckmonger1 1999 to 2016 Super Duty 0 04-18-2010 12:05 PM
Tags
01, 06, 2004, 97, ac, compressor, expedition, f150, ford, kick, navigator, power, pump, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
