Reverse shackel kit. Questions
Old 02-18-2011, 02:29 PM
dougbrown's Avatar
dougbrown
dougbrown is offline
Ok so I'm swapming my TTB for a Dana 60. I also want to do a rsk at the same time. I have a few questions for the guys that have done this.
1. This is where I found to get it from. Good place? 92-97 F-250/F-350 front shackle reversal - Sky's Off-road Design
2. Do I really need the sway arm on the rear? I know my Chebby K10 doesn't have on on it dana 44.
3. Can I use my stock shocks? I just put new Gas mactic shock on the truck at 137,800. Really don't want to have to get new ones.
4. Do I need the rear 4.5 shackel flip if I'm adding F350 blocks and going for a leave look.
5. Could someone post up some pictures of the rsk in the frame and behind the rear area. I know the difference it makes.
Thanks Doug.
Old 02-18-2011, 02:38 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
1. Good place. There is a guy on PSN that sells them too. OBSWIZ is his name
2. No
3. Yes stock should be fine
4. No. Just the blocks should do you fine
5. sorry no pics. Someone will though
Good luck.
Old 02-18-2011, 02:44 PM
dougbrown's Avatar
dougbrown
I'm going to have to joint psn and contact him then!
Old 02-18-2011, 05:09 PM
BadDogPSD's Avatar
BadDogPSD
BadDogPSD is offline
Cary (OBSWIZ) is a good guy. He's done a lot of R&D on the suspension mods for the OBS trucks and was one of the first, if not the first, to do the RSK with Super Duty springs.
I agree with everything Neal said. I can get you pic's of my set-up, but I used SD springs, so I had to move the RSK spring hanger forward about 3 1/2 " from the stock location. If you're using OBS F350 springs you will not need to do this (but the truck rides better with the SD springs...).
Old 02-18-2011, 05:50 PM
dougbrown's Avatar
dougbrown
Thanks Craig, I guess I will start looking around for a set of springs? So all I have to do is just measure spring bolt hole to bolt hole and move the front mount to match my spring hloe with.
Old 02-18-2011, 05:57 PM
dougbrown's Avatar
dougbrown
Are the springs from a F250 the same as F350 in the NBS?
Old 02-18-2011, 06:34 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
Hey man, im in the sameeeeee boat! My d60 is out being sand blasted right now! I have F-350 rear blocks....And i wanted to go with a RSK. They make a 3" and a 5" RSK....Well i know the d60 raises the truck up 2 inches...So if i go with a 3" RSK and the d60 thats 5" lift upfront....And 4" out back. WTF makes it level??
Old 02-18-2011, 06:57 PM
dougbrown's Avatar
dougbrown
I know that use the 3" rsk. I'm not sure but I know the back alreadu sit about 2 maybe 3" higher.
Old 02-18-2011, 07:16 PM
firemanp's Avatar
firemanp
firemanp is offline
Too bad you are not in or around the St. Louis area.. I have a set of virtually "0" mile U-codes from an '02 laying in the garage..
Old 02-18-2011, 07:22 PM
dougbrown's Avatar
dougbrown
Man that stinks. I have looked around Cl but came up empty.
Old 02-18-2011, 08:24 PM
BadDogPSD's Avatar
BadDogPSD
Try to find some 'V' codes if you can- they give a pretty good ride. Mine set-up is the D60, 3" SKY RSK, V code SD springs in the front,
4" F350 blocks and SD 'B' code springs in the rear. It sit's perfectly level. I like a little rake, so I'm going to swap the 4" block for 5" blocks once I
finish my other mods and pull it out of the garage.
The 'B' codes in the rear did not change my ride height, and honestly I didn't notice a change in the ride quality either.
You may already know, but the spring codes are different weight ratings. There should be a chart posted on here somewhere. I don't have it any more, but I know I've posted it.
In order, lowest to highest-- U, V, W, X. W would be good if you have a big heavy bumper & winch. X would be could if you plow, but not sure a plow mount would work with the RSK & SD spring set up...
Old 02-21-2011, 06:36 PM
bleeds blue's Avatar
bleeds blue
bleeds blue is offline
I just got my D60 installed two weeks ago. I already had a 4" lift and the D60 only lifted me 5/8". I reused the 250 springs until I have the money for the RSK. My guy said if I put the 5" kit in he can get a 5.25" rear block to make it pretty level.
Old 02-22-2011, 10:01 AM
rancher350's Avatar
rancher350
rancher350 is offline
I installed the 5" front shackel kit and the 4.5" rear kit from sky manu. and running 38's, I will see about downloading pic's. Tell me what kind of pic's your looking for.
Old 02-22-2011, 12:09 PM
jchosler's Avatar
jchosler
jchosler is offline
You dont need the sway bar, I dont have it and it has no more body role than stock. I have the 3.5" RSK kit and yes 350 blocks in the rear are good enough. I used the 350 shocks all the way around and have no problems. heres after pics
Old 02-25-2011, 06:02 PM
FordGod1's Avatar
FordGod1
FordGod1 is offline
Not trying to take over thread. Just curious what a RSK does?
Quick Reply: Reverse shackel kit. Questions
