trailer plug wiring
Old 02-18-2011, 11:10 AM
ChristopherN's Avatar
ChristopherN
ChristopherN is offline
trailer plug wiring
hello, i need to tow a small trailer that may have a max weight of 800lbs. if that. If I wire up the harness, can I tie into the tail lights with additional upgrades to the electrical?
note- I tried searching. already and have not found anything.
Old 02-18-2011, 12:48 PM
subford's Avatar
subford
subford is offline
That is the way U-Haul does it.
Old 02-18-2011, 02:36 PM
ChristopherN
Ah ok, perfect!
Oh, and I forgot a word so it should've said "no additional upgrades". I don't know if that will change things.
Old 02-18-2011, 02:41 PM
subford's Avatar
subford
subford is offline
There is also a "T" that you can buy and plug into the wiring.
Old 02-18-2011, 05:44 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
As mentioned above, NAPA carries a tee that plugs between the tail light harness, with a flat four pin trailer light plug. Easy as that, no cutting, no splicing. It's about $20.
Old 02-18-2011, 05:51 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
You can buy that same plug in at Wally World for less than Napa.
Old 02-18-2011, 09:44 PM
benbailey84's Avatar
benbailey84
benbailey84 is offline
Thumbs up
hellz yeah
Old 02-19-2011, 04:39 PM
ChristopherN
My wally world must have missed that memo because there was no tee plug available. Also, where is this fabled tee plug on the truck so this would be alot easier? I pulled the tail light bulb yesterday and was going to try and test the bulb jack with my multimeter by setting it on the sound so i could hear a result when I try the turning signal, etc. But I was getting ghost readings so I just wired in my leads and just tried a process of elimination with the trailer. I looked through my chiltons for the wiring diagram and that didn't help because it labled the brown and light blue/orange wires as "Stop turning running lights", useless pile of ****. I had both turn signals correct, but I could not get the stop and running lights to work together, it would cancel out each other and turn all the lights off on the trailer.
Old 02-19-2011, 04:54 PM
Bob Gervais
My local Walmart doesn't have them either.
The tail light connector is under the truck, toward the driver's side, around the fuel tank area. My harness had already been pulled out, so I'd be guessing on exact location, but it's in this general area. It's about 3/4" square, about two inches long.
Old 02-19-2011, 05:01 PM
ChristopherN
Ok, I see a junction of wires that split off three ways, is that it?
Old 02-19-2011, 05:05 PM
Bob Gervais
The factory wiring should only be a straight plug. If it weren't dark here already, I'd get you a pic. If you can wait until tomorrow, I'll climb under mine and take a pic of the factory connection, with the tee harness installed.
Old 02-19-2011, 05:06 PM
ChristopherN
That'll help and I can wait, thanks for understanding my novice-ness.
Old 02-19-2011, 05:09 PM
subford's Avatar
subford
subford is offline
You pull C401 apart and plug in the "T" to both of C401 plugs.
C401:
C401 location is under LH rear of vehicle, near rear crossmember (F6) in diagram below.
Old 02-19-2011, 05:11 PM
Bob Gervais
Subford to the rescue! Thanks, you saved me a trip under my truck in the wind and cold.
And it looks like I was wrong, it's a round connector. Sorry!
Old 02-19-2011, 06:13 PM
ChristopherN
Man I wish I would have tried the tee plug first. But I'm going to be stubborn and try wiring this myself since I already ran wires from the brake lights.
Quick Reply: trailer plug wiring
