84 l6 exhaust manifold - Ford Truck Enthusiasts Forums
Old 02-17-2011, 08:51 PM
Trilogy Trilogy is offline
Trilogy is starting off with a positive reputation.
My 84 f150 has a leak which was traced to the exhaust manifold gasket. The truck has the 300 4.9 l6 engine, any advice on changing the gasket and would it be better to change the whole manifold while I am there (I can buy the manifold for $150)?
Old 02-17-2011, 09:07 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
If you do end up changing the manifold, try and find one off an EFI 300 it is bigger and has much better flow and i've heard that it makes a good difference!
Old 02-17-2011, 09:10 PM
That won't have issues with a carb intake?
Old 02-17-2011, 09:12 PM
Think you might have to re-jet the carb but other than that, nope.
I've heard it's a direct bolt in swap.
Old 02-17-2011, 09:16 PM
dyingtolive's Avatar
dyingtolive dyingtolive is offline
dyingtolive is gaining momentum as a positive member of FTE.
In some cases, it's a direct bolt-in swap. Sometimes there is a tab on the manifold that has to be ground off in order to work with the stock intake. Some people have alternator clearance issues. And, if you put on EFI manifolds, you'll lose the heat pipe going from the stock manifold to the carb, so you'll have to fab up a heat plate to put on the bottom of the intake manifold so that it's heated. Otherwise you can start experiencing carb icing and the engine won't run right.
Old 02-17-2011, 09:23 PM
I don't think I have that heat pipe. The truck had a manuel choke put on it years ago and the heat riser was removed with the hole sealed shut when they did it. Makes for fun on cold New England mornings getting the truck started up. I have thought of trying to rebuild the choke, which would require the new manifold, heat riser and they choke.
Old 02-17-2011, 10:21 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
Whatever you decide to put on, take the assembled intake/exhaust to a machine shop and have it planed. It's cheap to do, and both the intakes and exhausts are known to warp. That might be what caused your initial problem.
Old 02-18-2011, 12:28 PM
Harfend's Avatar
Harfend Harfend is offline
Harfend is starting off with a positive reputation.
Another item to check before you start removing the entire exhaust manifold would be the exhaust pipe gasket found on your 84 4.9 I6 engine between the exhaust manifold and the header pipe. Later models had a metal to metal fitting at this connection. I understand this gasket was eliminated from this truck because of frequent failure... Might save you a bit of work because a bad exhaust pipe gasket could be mistaken for a bad exhaust manifold or gasket.
Good Luck!
HARFEND
Old 02-19-2011, 08:19 PM
Thank you for the tip. I will check more throughly before decided how to go about the task. Seems like it may be a pain to do, though mechanics won't even touch the manifold for leess then around $400 in labour.
1993 F150 Exhaust Manifolds - Gaskets? jeff9942 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2016 07:51 PM
Exhaust manifolds to headers 4fords 1997 - 2003 F150 3 11-29-2015 09:49 PM
78 F150 351 Need Exhaust Manifold Bolts and Gasket Question plcdwg101 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-04-2014 01:54 AM
Exhaust manifold collector gasket kyleag89 1997 - 2003 F150 3 11-23-2013 06:55 PM
Exhaust Manifold Leak skeneguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 02-09-2011 07:42 PM
Tags
1984, 1988, 300, 80, carb, choke, efi, exhaust, f150, ford, ga, heat, l6, manifold, manifolds, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
