Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 02-17-2011, 07:14 PM
Emel Emel is offline
2011 Ford F-350
Emel is starting off with a positive reputation.
Tires
Hello I have a 2011 AWD Edge it has p245/50 r20 pirelli outer diameter 29.7" and section with 10.0, I would like to instal GoogYear Fontera tripletred 275/55 r20 outer diameter 31.9 and section with 11.2. The diff is outer diameter 2.2", section with 1.2" Will this work, and will this confuse or mess up the computer system in the car,like traction control,sway control for the trailer tow,the breaking system AWD.Thanks,Emel
  #2 (permalink)
Old 02-18-2011, 11:49 AM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
Garage is empty, add now
38Chevy454 is starting off with a positive reputation.
If all four tires are the same, it should not affect the computer and brakes. It will make your speedometer to be off about 7.4%, using your figures for daimeter. You may have some clearance issues with wider width, are you also considering different wheels? If so pay attention to offset.
  #3 (permalink)
Old 02-22-2011, 07:55 PM
2011 Ford F-350
No the same wheels, 1" higher to the body & 1/2" wider in & out to the fender. Thanks for the info Emel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
