Which wire controls the door locks via Key Fob
Installing a remote start and everything says to use gray/yellow, however that wire only gives a pulse when the lock buttons on the doors are used, not on the fob. I need the wire that gives a negative pulse when the lock button on the fob is pressed.
The Gy-Ye wire is a ground side switch from the Smart Junction Box. All it does is supply a ground on the Lock signal circuit. The remote start will ground that circuit, thus telling the SJB to LOCK the doors. If you ground the Vt-Gy wire, the SJB will UNLOCK the doors. You will find those wires in the driver's side kick panel(be careful, there are multiple wires with that same color combo). The remote start module will activate your lock/unlock, you don't need the fob inputs.
I tried it and it doesn't. The gray/yellow is only getting a pulse when lock is hit on the door, not on the fob. Can anyone else verify this for me. My RS is a RS-130-DP and it needs a negative pulse 2 times from the unlock. It works fine if I hit lock on the door, but that makes the remote start a little pointless. The fob lock button does not affect gray/yellow.
Seems so weird that this pictorial/diagram never mentions pink/yellow
2010 remote starter wiring info and pics to match - Ford F150 Forum - Community of Ford Truck Fans
