Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 02-17-2011, 04:25 PM
Benjamin_R Benjamin_R is offline
1988 Ford F-150
Benjamin_R is starting off with a positive reputation.
pulling my hair out over this knock sensor
Can ANYONE tell me where to buy one of these damn things......looks like they are a discontinued item.......I broke mine off pulling emissions junk.......I have a 5.0 EFI......PLEASE PLEASE........my truck is running like a$$
  #2 (permalink)
Old 02-17-2011, 04:36 PM
lovemy85f150 lovemy85f150 is offline
Garage is empty, add now
lovemy85f150 is starting off with a positive reputation.
depending on what city your in : you could try your luck at the wreckers preferibly one that just deals in trucks and vans or just type the part in question into google or wich ever browser u use and you should get a few options hope this helps..
  #3 (permalink)
Old 02-18-2011, 06:30 AM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
Is your truck knocking that bad? All the sensor does is pulls out 4 degrees timing under knock. Sounds like you need a good top end treatment if you are getting that much knock. Just back off your timing at your distributor 4 degrees or so and see if that helps...should make the base about 6 degrees vs factory setting of 10.
  #4 (permalink)
Old 02-18-2011, 01:10 PM
rla2005's Avatar
rla2005 rla2005 is offline
2004 Ford Excursion
rla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to all
Some good info for some sources in this thread from another forum: Trouble Finding a Replacement Knock Sensor - FSB Forums
Tags
1992, 1996, 2011, 350, 58l, discontinued, f150, f350, ford, knock, nock, senser, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
