4R100 Slipping & Shuddering in Reverse - Ford Truck Enthusiasts Forums
Old 02-16-2011, 09:31 PM
bradleyj bradleyj is offline
bradleyj is starting off with a positive reputation.
I just drove my '02 7.3L Excursion home after having a new triple disk torque converter and Sonnax pressure regulator valve installed in the 4R100 tranny and when I was parking it at home I noticed that the transmission now slips and shudders in reverse. It was perfect before the install. No problems at all in forward. Fluid level is good. I shifted from forward to reverse like 20 times hoping that maybe some fluid circuits just needed to be filled, but it didn't help. I'm going to bring it back to the shop tomorrow, but anyone have any ideas of what might be going on here?
Old 02-17-2011, 06:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Fluid circuits will totally fill the first time it's put in reverse. Something probably went wrong with the install.
Old 02-17-2011, 07:27 AM
What could go wrong with a TC and PRV replacement that could affect only reverse? I would think that any problems associated with replacing these parts would be evident in all gears.
Old 02-17-2011, 05:17 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
Reverse requires a lot more line pressure to operate than the forward gears, if the pressure regulator valve train was improperly installed or has a problem it may not be able to produce the line pressure needed for reverse to work properly. The use of a pressure gauge will tell if the line pressure is sufficient or not.
Reverse line pressure at idle - 75-99 / stall - 240-265
Drive line pressure at idle - 55-65 / stall - 156 - 174
4r70w no reverse then bucking in reverse whateg01 Clutch, Transmission, Differential, Axle & Transfer Case 4 09-12-2016 12:06 AM
shudder in reverse 4R100 donmi Clutch, Transmission, Differential, Axle & Transfer Case 3 11-02-2015 09:44 PM
Yet another 4r100 problem. scottddove 1999 - 2003 7.3L Power Stroke Diesel 3 08-30-2015 10:45 PM
After Transmission Service, truck stalls in reverse Jesser02EX 1999 - 2003 7.3L Power Stroke Diesel 7 06-05-2013 11:47 PM
4r100 slipping bugaloo 1999 to 2016 Super Duty 1 07-01-2009 03:26 PM
Tags
2006, 4r100, 96, f150, f350, forward, gears, problems, reverse, shudder, shuddering, slip, slips, transmission, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
