390 headers
Old 02-16-2011, 06:04 PM
NW 150's Avatar
NW 150
NW 150 is offline
390 headers
has anyone hear put a set of headers on a 390 in an f100/f150 73-79?
I will in about a month, and my set is different than any set ive ever seen. On the pass. side the front two pipes go in front, down and around the engine mount, and the back two look to somehow bend around the starter and head down to the collector. the drivers side don't look bad, just don't know what will have to be taken off periodically to get the header in.
Just wondering how easily/hard they go in and any tips for installation. The manifold bolts are all loose (as in none will snap. i can get them off no problem). so thats out of the picture thank God.
And do headers really wake up this engine?
Old 02-16-2011, 07:52 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
I can't say much about them in a f100/150 but headers really do make a pretty big gain. The most restrictive thing on these is the exhaust manifolds.
Old 02-16-2011, 08:08 PM
allwthrrider's Avatar
allwthrrider
allwthrrider is offline
Don't know how much of a difference there is but on my 70 F350 just had to lift the left side a few inches & they went in just fine, right side came down from the top, I have a C6 trans & had to smash the pipe in so the shift lever didn't rest on the exhaust
Old 02-16-2011, 08:34 PM
NW 150's Avatar
NW 150
NW 150 is offline
yea here are some pictures:
and i don't use left and right so which side are you talking about when you say left?
My tranny is a t18
Old 02-16-2011, 08:55 PM
allwthrrider
As sitting in drivers seat, Left Driver side, Right Passenger side, To many years working on Aircraft I guess
Old 02-16-2011, 09:02 PM
NW 150's Avatar
NW 150
NW 150 is offline
well the pass side splits in two, after you cut the rest of the flange where the pre-cut is. and it supposedly fits around the pedestal or whatever you call it that the mount bolts to. i don't mind if i have to grind some of it away, but the starter seems to maybe be in the way. i'll find out i guess lol
Old 02-16-2011, 10:23 PM
7Ford6's Avatar
7Ford6
7Ford6 is offline
What brand headers are those? I wouldn't cut that flange as your probably gunna have to lift that side up as well.. The starter is a tight fit, even with a mini starter it can be a real pain, as you'll find out soon enough.. A bit of a juggling trick to it.. Re-Build the starter or go with a mini-starter when it's out and use heat wrap on it as it will sit real close to the pipes... do a search a read some previous threads on the subject...
Old 02-17-2011, 12:05 AM
big78f150's Avatar
big78f150
big78f150 is offline
my dads truck has a 360 with headers similar to that. my uncle put them on and he had to jack the motor up a few inches to put them in. but it clears the starter fine, it is a little close tho.
Old 02-17-2011, 08:12 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I used headers just like those in my highboy. The passenger side came apart so you could install them without removing the motor mount pedestal or even jacking the motor up to clear the flange. They did clear the starter, and it took some moving it around, but I could replace the starter without removing the header.
I think, if you pull the starter, disconnect the passenger-side motor mount, and jack the engine up as far as you can go, you can install that header from the bottom by sneaking the header flange between the block and the pedestal. Removing the motor mount from the engine might help too.
Old 02-17-2011, 12:29 PM
NW 150's Avatar
NW 150
NW 150 is offline
flowtech. you cut the flange the rest of the way, and slip it apart, as the two tubes for the front half slide out of the collector (notice the line in the picture). the instructions say to install the rear first, and then the front.
Old 02-17-2011, 12:31 PM
NW 150's Avatar
NW 150
NW 150 is offline
yea i just look in the and think it will be a tight fit. Can't tell until i get them in though, but i hope you word is good and they fit in my truck too.
Old 02-17-2011, 12:33 PM
NW 150's Avatar
NW 150
NW 150 is offline
i'll try and install it without jacking up the engine, but if i have to i will. How easy is the drivers side? i have a t18 so theres some stuff there and i don't know if i have to take anything off temporary for installation.
Old 02-22-2011, 02:11 AM
lonnie1952's Avatar
lonnie1952
lonnie1952 is offline
I put Headers on my 1973 F100 390
Tight fit..makes changing the starter a Bear....
Use a Starter heat sheild
Better fuel economy and torque
Worth the swap
1952
Old 02-23-2011, 09:11 AM
NW 150's Avatar
NW 150
NW 150 is offline
was yours a 4x4?
Old 03-18-2011, 07:58 AM
NW 150's Avatar
NW 150
NW 150 is offline
I posted a new thread in the 73-79 section. Got the headers in last week and they went on easy as hell. One of the easiest things i've ever done.
ol-blu
06-12-2020 11:17 PM
99ARTaco
01-17-2017 08:08 AM
Don Vito
08-19-2016 09:55 AM
DillonZ81ford
07-30-2016 06:55 PM
Drunken_Unicorn
07-12-2015 09:11 PM
Quick Reply: 390 headers
