Fuel FIlter Change - in the Information Center
Old 04-07-2013, 07:34 PM
desertnomad's Avatar
desertnomad
desertnomad is offline
Old 04-07-2013, 07:35 PM
Bmacs's Avatar
Bmacs
Bmacs is offline
Djousma,
Darn - never had to reset the coolant test... I was just out there again and couldn't find it.. nothing in the manual either...
Have you had to reset the fuel filter in your truck?
Thanks,
Bill
Old 04-07-2013, 07:37 PM
Bmacs's Avatar
Bmacs
Bmacs is offline
desertnomad,
NOTHING in the video about resetting the message... I've watched it 3 times....
Thanks,
Bill
Old 04-07-2013, 07:47 PM
Bmacs's Avatar
Bmacs
Bmacs is offline
Found it!
Djousma,
Your tip for the coolant reset helped me find it...
Settings > Vehicle > Maintenance > Fuel Filter Reset
Thanks to all for the pointers...
Bill
Old 04-07-2013, 09:03 PM
kper05's Avatar
kper05
kper05 is offline
Originally Posted by Bmacs
Djousma,
Thanks,
Bill
Hum...coolant test should occur every 15,000 so I've surprised your truck hasn't thrown this alert.
Old 04-08-2013, 05:49 AM
RM2012F350's Avatar
RM2012F350
RM2012F350 is offline
It is under settings...
RM2012F350,
Do you have a little more detail than that?
I've been through the menus. There is an "oil life reset" - but no "fuel filter reset"
Have you reset the fuel filter through the menus yourself?
Thanks,
Bill
Yes, I have reset the filter life on my 11 & 12.
Go to settings;
Vehicle:
Maintenance:
Fuel Filter:
press and hold...
Old 04-08-2013, 05:57 PM
AFSDDude's Avatar
AFSDDude
AFSDDude is offline
Light never came on for me; got to 22,800 miles and truck throttle response was sporadic one morning on way to work. Called the dealer right then and scheduled the changes. Pretty simple. I'll do it myself when 15k goes by. Wonder if Baldwin makes a filter to fit this app. Been running Baldwins for years in my other diesels.
Thanks OP for the write-up.
Old 05-08-2013, 08:54 AM
jlalanas's Avatar
jlalanas
jlalanas is offline
I just received my first "change fuel filter" message in the cluster at 32,300 miles. I've been changing them every 10k. Last time I changed them was right around 30,000. I'm going to just reset the message and continue with my normal maintenance schedule.
Old 05-08-2013, 09:08 AM
marchare011's Avatar
marchare011
marchare011 is offline
Do you think you just forgot to reset the reminder last filter change, or could there be a plugging issue with the filters?
Old 05-08-2013, 10:09 AM
GMUGNIER's Avatar
GMUGNIER
GMUGNIER is offline
I don't understand what is up with the minders - the minder on my truck has only went off once and I have almost 60k on my clock - Talked directly to service department, and the service manager told me "If you don't change your filters every 20k it will void your warranty"
Old 05-08-2013, 12:15 PM
sobiloff's Avatar
sobiloff
sobiloff is offline
The "minder" is actually a warning indicating that your filters are clogged. The Diesel Supplement says to change both filters "Every 22500 miles (36000 kilometers) or as indicated by the information display" (p. 77) as part of your regularly scheduled maintenance. So your dealer's pretty close with his comment.
Old 05-08-2013, 05:08 PM
GMUGNIER's Avatar
GMUGNIER
GMUGNIER is offline
The or as indicated part is what I have been paying attention to
  #28
Old 05-08-2013, 07:09 PM
sobiloff's Avatar
sobiloff
sobiloff is offline
Yeah, the manual should probably add "whichever comes first." At least, that's how I read it...
  #29
Old 05-08-2013, 08:37 PM
GMUGNIER's Avatar
GMUGNIER
GMUGNIER is offline
Yes - I agree - but from now on - every 20k for me...... Also the service manager advised me that regular driving (to and from work) without actually "working" the truck - constitutes a "severe" duty scenario where all fluids and filters need to be changed on a more regular basis.
  #30
Old 05-09-2013, 12:21 AM
desertnomad
If you fall under "Special operating conditions" the manual states Every 15,000 miles
(24,000 km), 6 months, 600 engine hours or as indicated by message center. I first changed mine at ~14,000 and will do so again at 28,000 or less. I call it cheap insurance.
Headviking
6.4L Power Stroke Diesel
04-11-2017 04:35 AM
djousma
6.7L Power Stroke Diesel
10-04-2016 04:18 PM
littleapple
1999 to 2016 Super Duty
01-19-2016 09:56 AM
Byram
10-30-2013 07:02 PM
KC8QVO
01-20-2011 04:08 PM
Quick Reply: Fuel FIlter Change - in the Information Center
