??'s about 6"RoughCountry lift ima buy
im buyin a 6" suspension lift for my 5spd 93 f150...
its a Rough Country liftkit! in the front its includes free single steering stablizer, hydro 8000 shocks, Lifted coil springs, radius arm drop brackets, I-beam drop brackets, and power steering pitman arm. in the rear it includes 3" lift blocks and add-a-leafs and u bolts!!!!
now the ???
do i need extended breaklines and/or any other parts??
help please before i order the kit
now the ???
This is total BS, I installed a 4 inch in my pickup, and with the front still on the jackstands, I had to slightly bend the metal part of my extended lines so they where not tight. The rear might not need a extended line, I didnt use one on mine in the back, but the front is needed for sure.. That is unless, you take them out of the stock frame location and make a new lower bracket for it.
ur suspension hadnt even settled yet, it was probly sitting a lot higher than it is now
its do-able, just to his there own
One good bump and its possible to pinch or break a line if not running them attached to the frame because you are too cheap to buy ~$35 worth of brake lines.
possible in your mind, not mine. i know plenty of people running there trucks like this. YOU DO WHAT YOU WANT and i will do what i want. even though i have ext brake lines on my project. you don't absolutely need them
Have you put your lift in yet? I bought a 6" lift last week from Rough Country and installed it over the weekend. The extended brake lines that they sent me for the front are actually no longer than the stock lines. I called them and they said that they only had 1 set of lines available for that year.
