Replacing Universal Joints - Ford Truck Enthusiasts Forums
Old 02-16-2011, 09:19 AM
Justin's Green Truck's Avatar
Justin's Green Truck Justin's Green Truck is offline
Justin's Green Truck is starting off with a positive reputation.
Hi, we have two 99 F150's where I work and they both need new u-joints. One is 4X4 and the other is two wheel drive. Both are automatic trans, 4.6L
I know how to remove the driveshaft from the vehicle, but have never changed u-joints. Is there any special tool or technique required to drive them out? Thanks.
Old 02-16-2011, 12:04 PM
moto57's Avatar
moto57 moto57 is offline
moto57 is starting off with a positive reputation.
Rent(free) a U Joint press from a local Auto parts store, lock the press in a bench vise. or Old School using a BFH and Sockets.
Don't forget before you remove the drive shafts to use a marker to mark the relation of the shaft and the slip yoke(they are balanced) Oh yea, a little PB helps too.
Old 02-16-2011, 01:31 PM
N832 N832 is offline
N832 is starting off with a positive reputation.
I like to take out the drive shaft then take it to a driveline shop. They will replace the joints and balance for a very small fee. saves the headache and then they are balanced. The picture shown is a ball joint press. It should work if you set it up right..
Old 02-16-2011, 04:43 PM
moto57's Avatar
Quote:
It's listed as a Ball Joint/U Joint/C frame Press, It does works great!
I was refering to marking the Drive Shaft/Differential Pinion Flange before you remove the bolts holding both together so they get reinstalled in the same exact position that you removed them. These marks ensure that the drive shafts dynamic balance will be restored when the driveshaft is installed again.
79 F350 4x4 U-Joint Problem Tailgate55 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-16-2014 08:02 PM
Drive Shaft/U-Joint Help wkp 2004 - 2008 F150 0 09-17-2012 11:21 AM
Which u-joint press temptee 1987 - 1996 F150 & Larger F-Series Trucks 9 06-22-2008 03:09 PM
u-joints f350 tietje_3 1999 to 2016 Super Duty 5 10-13-2006 09:32 PM
Part number help! Spicer U-Joint rondog 1987 - 1996 F150 & Larger F-Series Trucks 4 09-06-2001 01:21 PM
Tags
2003, 96, changing, driveline, duty, f150, ford, joint, joints, replace, super, truck, trucks, ujoints, universal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
