Ring Gear size? - Ford Truck Enthusiasts Forums
Ring Gear size?
Old 02-16-2011, 08:17 AM
Golflug's Avatar
Golflug Golflug is offline
Golflug is starting off with a positive reputation.
Ring Gear size?
Can someone help me out here.
My sons 97 f-150 extended cab 2 wheel drive has a very minor bent axle on the drivers side. I have been looking for a new axle for him and the most common one listed is for a 9.75" ring gear. But I have seen a few listed that fit an 8" ring gear.
His axle code is H9 which I found is a 3.55 Limited slip rear end, but I can't find any information as to what size ring gear I may have.
The numbers on the rear end tag don't match anything I have seen listed anywhere.
Rear end tag...6869B R 3L55 88 7F12
Anyone have any ideas?
I went ahead and ordered him a 9.75" since this is the most common, but I just have this bad feeling I may have the wrong one
Old 02-16-2011, 09:11 AM
MIKE 04 GT MIKE 04 GT is offline
MIKE 04 GT is starting off with a positive reputation.
the 88 on the tag i beleave means it has the 8.8 rear axle.
Old 02-16-2011, 09:33 AM
jerem0621 jerem0621 is offline
jerem0621 is gaining momentum as a positive member of FTE.jerem0621 is gaining momentum as a positive member of FTE.
Mike,
You are correct. it is an 8.8 rear.
OP,
also you can count the bolts in the rear end. An 8.8 will have 10 bolts. A 9.75 will have 12 bolts. I have heard of the rare occasion where the tag may not match the rear end. Just to be sure, count the bolts.
Thanks!
Old 02-16-2011, 11:45 AM
Golflug's Avatar
Thanks, I was afraid that after I ordered it and he finally sent the tag numbers that the 88 would mean an 8.8 Now have to send this one back when it arrives and try to find the right one.
9.75 ring gear vs 8.8 axle bearing toby tough 1997 - 2003 F150 2 09-28-2015 09:00 PM
REAR AXLE QUESTION!! Ranger Bob 2004 - 2008 F150 50 08-03-2014 07:34 PM
Ring Gear Size bluecobra 1997 - 2003 F150 6 07-01-2014 03:50 PM
THIS IS AN ODD CASE!! 8.8 RING GEAR BUT TAGS SAY 9.75? Welder Guy 1997 - 2003 F150 1 05-29-2012 08:23 PM
Ring gear size for 1988 F250 4x4? newfordguy88 Clutch, Transmission, Differential, Axle & Transfer Case 6 11-14-2005 11:05 AM
Tags
04, 150, 1999, 2005, dimensions, f150, f250, f350, find, ford, gear, h9, reaend, ring, size, sizes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
